[mapguide-users] asp.net example of loading a webmapservice layer
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Feb 19 08:32:14 EST 2009
Not sure what goes wrong, but "Nothing" or "null" is the right value.
The MgDbXml exception should write an entry in the log file, stating
what the value is.
Regards, Kenneth Skovhede, GEOGRAF A/S
stoff skrev:
> Thanks Kenneth, thanks Dave for your Hints.
> Here is my effort. In line 139 I get an error, cause I don't know what to
> pass as header-parameter in objMGResourceService.SetResource(). In PHP it is
> null, in asp.net nothing does not work (MgDbXMLException). I tried to load
> the given temp.layerDefinition.xml.
> Do you know any examples on loading ogc stuff like catalogservices, wms,
> layers ... ?
> http://n2.nabble.com/file/n2352287/ogc_services.aspx.vb ogc_services.aspx.vb
> http://n2.nabble.com/file/n2352287/temp.FeatureSource.xml
> http://n2.nabble.com/file/n2352287/temp.LayerDefinition.xml
> Looking forward to a solution,
> stoff
