[mapguide-users] Creating package problem in maestro
padmini godavarthi
godavarthi.padmini at gmail.com
Fri Feb 20 11:06:25 EST 2009
Thanks for ur reply.
i tried it and it works fine.
Now i have another problem
1) I applied some colors to the features(polygons) based on the "By Adding
Rules" in the layer(using maestro)
for example :- polygons with Resedential area-i applied red color
polygons with commercial are- i applied green color and so on
i have loaded the map and it works fine with appropriate given colours.
after that i have changed 1 polygon to ( Resedential into commercial area)
in the database by using alter command.
While loading again the map the modified feature is not displaying on the
map (may be missing)
Did anything done in the wrong way????????????????????????????????????
2) iam unable to select the features on the map even after i checked the
option that "Feature on the layer are selectable"(if visible) option.
Thanks and Regards,
Padmini.
ravinder.singh wrote:
> Hi,
> Make an entry in table: ALL_SDO_GEOM_METADATA of MDSYS Schema in Oracle.
> You will find entries of all your layers which you have imported in
> oracle, but entries for views will not be there, so you have to enter
> entries of all of your views for which you want to create the layers.
> Then go to maestro you fill find your view now.
> Hope this will solve your problem.
> Thanks & Regards,
> Ravinder
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of padmini
> godavarthi
> Sent: Friday, February 20, 2009 7:03 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Creating package problem in maestro
> Hi,
> iam using mapguide opensource 2.0 (with .net 2.0 +IIS 5.1)
> Now my problem is that
> While creating a package using mapguide maestro
> 1) i have created 1 feature resource for my oracle user
> 2) Next i want to create a layer (by using a view in my database) .
> but my problem is that my view is not displaying on the schema combo box
> http://n2.nabble.com/file/n2358845/maestro.jpeg
> can we able to load layer in the form of database view
> plz tell me the solution
> http://n2.nabble.com/Creating-package-problem-in-maestro-tp2358845p23588
> 45.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> "This message and any attachments are solely for the intended recipient
> and may contain Birlasoft confidential or privileged information. If you
> are not the intended recipient,any disclosure,copying, use, or
> distribution of the information included in this message and any
> attachments is
> prohibited. If you have received this communication in error, please
> notify us by reply e-mail at (administrator at birlasoft.com) and permanently
> delete this message and any attachments. Thank you."
View this message in context: http://n2.nabble.com/Creating-package-problem-in-maestro-tp2358845p2359658.html
