[mapguide-users] Impossible To connect trougth ODBC to .csv
Micho Gar michogar at gmail.com
Mon Feb 23 05:46:49 EST 2009
Ok, sorry for repeating the question, but it is very necessary to resolve
this.
Greetings.
2009/2/20 Dave Wilson <dave.wilson at autodesk.com>
>  As mentioned in an earlier thread there is a bug on this and even though
> you might be able to make the feature source your layer will fail to
> preview.
> It looks like the bug is an issue with the file lookup. FDO has mapped the
> "table" name to the file name but instead of the period substituted an
> underscore so when sending the request to the provider it appears to be
> looking for filename_csv for the table name instead of filename.csv which is
> what the ODBC DSN is expecting.
> Bottom line is it doesn't work.
> Dave
> *From:* mapguide-users-bounces at lists.osgeo.org [mailto:
> mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Micho Gar
> *Sent:* Friday, February 20, 2009 2:25 AM
> *To:* MapGuide Users Mail List
> *Subject:* [mapguide-users] Impossible To connect trougth ODBC to .csv
> Hi all,
> After many attempts I have not been able to connect to a file .csv. Do you
> know if you can connect somehow to a text file?.
> Greetings and thanks
> # michogar
> # Analista Programador SIG
> # Ubuntu Linux Counter 462666
> "Cuenta una leyenda que si reproduces un DVD de Windows Vista original al
> revés se oye a Bill Gates entonando cantos satánicos... Pero eso no es lo
> peor... Si lo reproduces del derecho... ¡Se instala!."
> "It has a legend that if you play an original Windows Vista DVD backwards
> to hear Bill Gates Satanic chanting songs ... But that's not the worst ...
> If you play it right ... It installs!.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
# michogar
"It has a legend that if you play an original Windows Vista DVD backwards to
hear Bill Gates Satanic chanting songs ... But that's not the worst ... If
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090223/e8b7f28d/attachment.html
