[mapguide-users] Impossible To connect trougth ODBC to .csv
Zac Spitzer
zac.spitzer at gmail.com
Mon Feb 23 06:46:27 EST 2009
you could always load the text file into a database and read it that way
z
On Mon, Feb 23, 2009 at 9:46 PM, Micho Gar <michogar at gmail.com> wrote:
> Ok, sorry for repeating the question, but it is very necessary to resolve
> this.
> Greetings.
> 2009/2/20 Dave Wilson <dave.wilson at autodesk.com>
>> As mentioned in an earlier thread there is a bug on this and even though
>> you might be able to make the feature source your layer will fail to
>> preview.
>> It looks like the bug is an issue with the file lookup. FDO has mapped the
>> "table" name to the file name but instead of the period substituted an
>> underscore so when sending the request to the provider it appears to be
>> looking for filename_csv for the table name instead of filename.csv which is
>> what the ODBC DSN is expecting.
>> Bottom line is it doesn't work.
>> Dave
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Micho Gar
>> Sent: Friday, February 20, 2009 2:25 AM
>> To: MapGuide Users Mail List
>> Subject: [mapguide-users] Impossible To connect trougth ODBC to .csv
>> Hi all,
>> After many attempts I have not been able to connect to a file .csv. Do you
>> know if you can connect somehow to a text file?.
>> Greetings and thanks
>> # michogar
>> # Analista Programador SIG
>> # Ubuntu Linux Counter 462666
>> "Cuenta una leyenda que si reproduces un DVD de Windows Vista original al
>> revés se oye a Bill Gates entonando cantos satánicos... Pero eso no es lo
>> peor... Si lo reproduces del derecho... ¡Se instala!."
>> "It has a legend that if you play an original Windows Vista DVD backwards
>> to hear Bill Gates Satanic chanting songs ... But that's not the worst ...
>> If you play it right ... It installs!.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> # michogar
> "It has a legend that if you play an original Windows Vista DVD backwards to
> hear Bill Gates Satanic chanting songs ... But that's not the worst ... If
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
