[mapguide-users] Weblayouts Buil-in commands
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Wed Feb 25 06:54:08 EST 2009
That depends on what you mean by "edit/customize".
If you mean "change the text" (eg, translate), you can do so with
MapGuide Maestro, or you can manually modify the underlying xml.
If you mean "alter functionality", you can look in the
"ajaxmappane.templ" file and modify the javascript there.
Regards, Kenneth Skovhede, GEOGRAF A/S
Rui Daniro skrev:
> Hi all,
> I am usig MGE 2009 and I would like to know if it is possible edit/costumize
> built-in commands. If yes, where and how can I get the code.
> Thanks in advance.
> Rui
