[mapguide-users] Weblayouts Buil-in commands
Steve G
steve.golden at morganhill.ca.gov
Wed Feb 25 11:24:35 EST 2009
It is typically installed here:
C:\Program Files\MapGuideOpenSource2.0\WebServerExtensions\www\viewerfiles
Rui Daniro wrote:
> Hi Kenneth,
> I meant alter functionality. You said I can look in the
> "ajaxmappane.templ"
> file and modify the javascript there, so where I can find that file?
> Thanks
> Rui
> _____
> De: Kenneth Skovhede, GEOGRAF A/S (via Nabble)
> [mailto:ml-user+64672-1645459268 at n2.nabble.com]
> Enviada: 25 February 2009 11:54
> Para: Rui Daniro
> Assunto: Re: [mapguide-users] Weblayouts Buil-in commands
> That depends on what you mean by "edit/customize".
> If you mean "change the text" (eg, translate), you can do so with
> MapGuide Maestro, or you can manually modify the underlying xml.
> If you mean "alter functionality", you can look in the
> "ajaxmappane.templ" file and modify the javascript there.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Rui Daniro skrev:
>> Hi all,
>> I am usig MGE 2009 and I would like to know if it is possible
> edit/costumize
>> built-in commands. If yes, where and how can I get the code.
>> Thanks in advance.
>> Rui
> mapguide-users mailing list
> mapguide-users at ...
> <http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2383299&i=0>
> _____
> This email is a reply to your post @
> http://n2.nabble.com/Weblayouts-Buil-in-commands-tp2383047p2383299.html
> You can reply by email or by visting the link above.
View this message in context: http://n2.nabble.com/Weblayouts-Buil-in-commands-tp2383047p2384604.html
