[mapguide-users] Source Code for GT - Test Application
Steve G steve.golden at morganhill.ca.gov
Wed Feb 25 17:10:42 EST 2009
Sorry, just realized one ommission when I pushed my code over to the
production side.
5.  Make sure your user has an assigned role of "User Level" (Map Author
role works).  If not, you will not be able to create new markup layers.
Steve G wrote:
> Thanks...both of your suggestions fixed the problem.  I hadn't set the
> coordinate system in the map and then needed to change
> MgCoordinateSystemTransform.  The first error was just dumb on my part.
> Here are my full instructions on how to get the shareable markups to work
> using MG 2.0.2.  Not sure if this is the best place to put this or if it
> can be copied in a wiki somewhere...
> 1.	Extract GT.zip to folder called Markup in
> C:\Program Files\MapGuideOpenSource2.0\WebServerExtensions\www
> There are some extra files that you don’t need specifically for shareable
> markup tool (other tools in the GT sample application), but it won’t hurt
> to extract all the files here.
> 2.	Place gtconstants.php in
> 3.	C:\Program
> Files\MapGuideOpenSource2.0\WebServerExtensions\www\phpviewersample
> 4.	Edit gtconstants:
> $INSTALL_DIR = 'C:\\Program Files\\MapGuideOpenSource\\';
> to
> $INSTALL_DIR = 'C:\\Program Files\\MapGuideOpenSource2.0\\';
> If you installed MG to another directory or if the default directory name
> changes, you will need to update this.
> 3.	Make sure that your coordinate system is set in your map.  If not, you
> will get an error that says this:
> Argument is null.
> Argument is null. Exception occurred in method MgCoordinateSystemCache.Get
> at line 120 in file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\common\geometry\CoordinateSystem/CoordinateSystemCache.cpp
> 4.	Open:
> Files\MapGuideOpenSource2.0\WebServerExtensions\www\phpviewersample\markup\classes\markupeditor.php
> On line 57 change
> return new MgCoordinateSystemTransform($source, $target);
>  to
> return $coordSysFactory->GetTransform($source, $target);
View this message in context: http://n2.nabble.com/Source-Code-for-GT---Test-Application-tp2305046p2386459.html
