[mapguide-users] Regarding -- Run Time Maps vs Static Maps
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Feb 26 04:20:30 EST 2009
1) There is no difference in how you create the maps, the viewer doesn't
know, and doesn't care.
2) Development (as in coding) is less if you just create the maps in
Studio/Maestro, but development (as in administrating maps) may grow,
and cannot be easily automated.
3) I would expect this to be an insignificant issue.
4) I have no good guess.
5) I'm pretty sure that the maps saved with Studio/Maestro will be
supported "forever".
You can save a little overhead, if you save the generated maps into the
"Library://" repository, instead of the "Session:" one.
It requires slightly higher privileges to do so (author role?), but that
way, you can automate the build of maps,
and just point to the correct one on startup.
Regards, Kenneth Skovhede, GEOGRAF A/S
ravinder.singh at BIRLASOFT.COM skrev:
> Hi,
> I want to get suggestions/opinions from all of you.
> I have hundreds of layers available in Shape File (.shp) format.
> Each layer represents an individual map.
> And on the fly I link layer with map and map to the layout.
> And I also got success in doing that.
> But I found problems with run time maps. E.g. Setting/Getting
> Selections related and More Development Efforts.
> So now my question is should I make static maps with static layouts?
> Or should I Continue with Run time maps?
> Means should I create each map and each layout in maestro itself. And
> call the respective layout whichever I need at run time.
> Which is the best approach in respect of the following?  I have listed
> the below features according to my priority from higher to lower.
> I am more concern with high priorities.
> Priority 1. Functionality & Features of Viewer.
> Priority 2. Development Efforts.
> Priority 3. Load on Map Server.
> Priority 4. Resource Consumption like Memory.
> Priority 5. In respect of Future Adaptability of MGOS Versions.
> The rest of the features if you can suggest/think of can also be included.
> *Thanks & Regards,*
> Ravinder
> *********************************************************************************************************************************************************************%CRLF%"This message and any attachments are solely for the intended recipient and may contain Birlasoft confidential or privileged information. If you are not the intended recipient,any disclosure,copying, use, or distribution of the information included in this message and any attachments is %CRLF%prohibited. If you have received this communication in error, please notify us by reply e-mail at (administrator at birlasoft.com) and permanently delete this message and any attachments. Thank you."%CRLF%*********************************************************************************************************************************************************************%CRLF%
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090226/c8c9c157/attachment.html
