[mapguide-users] problem building mapguide from svn
alucas alucas at svl.es
Thu Feb 26 07:20:44 EST 2009
Hi Jackie,
I've installed the FDO 3.4.0 RC1 SDK for RHEL4. I didn't build it.
Thanks.
Jack Lee-3 wrote:
> Hi,
> Did you build and install Fdo?
> alucas wrote:
>> Hello,
>> I'm trying to build mapguide from svn and I'm getting this error in the
>> make
>> command:
>> make[2]: se ingresa al directorio `/tmp/mgos21/MgDev/Common/Stylization'
>> if /bin/sh ../../libtool --tag=CXX --mode=compile g++
>> -DPACKAGE_NAME=\"mapguide\" -DPACKAGE_TARNAME=\"mapguide\"
>> -DPACKAGE_VERSION=\"2.0.0\" -DPACKAGE_STRING=\"mapguide\ 2.0.0\"
>> -DPACKAGE_BUGREPORT=\"http://mapguide.osgeo.org\" -DPACKAGE=\"mapguide\"
>> -DVERSION=\"2.0.0\" -DPACKAGE=\"mapguide\" -DVERSION=\"2.0.0\"
>> -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1
>> -DHAVE_STDLIB_H=1
>> -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1
>> -DHAVE_INTTYPES_H=1
>> -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -DSTDC_HEADERS=1
>> -DHAVE_UNISTD_H=1 -DHAVE_MATH_H=1 -DHAVE_NETDB_H=1 -DHAVE_NETINET_IN_H=1
>> -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_SOCKET_H=1 -DHAVE_GETHOSTBYNAME=1
>> -DHAVE_SOCKET=1 -DHAVE_HTONS=1 -DHAVE_CONNECT=1 -DHAVE_SHUTDOWN=1  -I.
>> -I.
>> -I../MdfModel/ -I../Foundation -I/usr/local/fdo-3.4.0/include
>> -I/usr/local/fdo-3.4.0/include/ExpressionEngine
>> -I../../Oem/ACE/ACE_wrappers
>> -O2 -g -pipe -march=i386 -mcpu=i686 -fno-use-cxa-atexit -fexceptions -MT
>> Band.lo -MD -MP -MF ".deps/Band.Tpo" -c -o Band.lo Band.cpp; \
>>         then mv -f ".deps/Band.Tpo" ".deps/Band.Plo"; else rm -f
>> ".deps/Band.Tpo"; exit 1; fi
>>  g++ -DPACKAGE_NAME=\"mapguide\" -DPACKAGE_TARNAME=\"mapguide\"
>> -DPACKAGE_VERSION=\"2.0.0\" "-DPACKAGE_STRING=\"mapguide 2.0.0\""
>> -DHAVE_STDLIB_H=1
>> -DHAVE_INTTYPES_H=1
>> -DHAVE_SOCKET=1 -DHAVE_HTONS=1 -DHAVE_CONNECT=1 -DHAVE_SHUTDOWN=1 -I. -I.
>> Band.lo -MD -MP -MF .deps/Band.Tpo -c Band.cpp  -fPIC -DPIC -o
>> .libs/Band.o
>> `-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.
>> In file included from Band.h:21,
>>                  from Band.cpp:20:
>> Stylization.h:78:33: error: FdoExpressionEngine.h: No such file or
>> directory
>> Stylization.h:79:51: error: FdoExpressionEngineFunctionCollection.h: No
>> such
>> file or directory
>> Stylization.h:80:54: error: FdoExpressionEngineINonAggregateFunction.h:
>> No
>> such file or directory
>> make[2]: *** [Band.lo] Error 1
>> make[2]: se sale del directorio `/tmp/mgos21/MgDev/Common/Stylization'
>> make[1]: *** [all-recursive] Error 1
>> make[1]: se sale del directorio `/tmp/mgos21/MgDev/Common'
>> make: *** [all-recursive] Error 1
>> Any Idea?
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/problem-building-mapguide-from-svn-tp2385016p2389294.html
