[mapguide-users] problem building mapguide from svn
Jack Lee jack.lee at sympatico.ca
Thu Feb 26 08:34:58 EST 2009
There seems to some problems with the Linux sdk tar file. Some header
files and libraries are missing.
Until this is fixed, you would need to build and install Fdo.
alucas wrote:
> Hi Jackie,
> I've installed the FDO 3.4.0 RC1 SDK for RHEL4. I didn't build it.
> Thanks.
> Jack Lee-3 wrote:
>> Hi,
>> Did you build and install Fdo?
>> alucas wrote:
>>> Hello,
>>> I'm trying to build mapguide from svn and I'm getting this error in the
>>> make
>>> command:
>>> make[2]: se ingresa al directorio `/tmp/mgos21/MgDev/Common/Stylization'
>>> if /bin/sh ../../libtool --tag=CXX --mode=compile g++
>>> -DPACKAGE_NAME=\"mapguide\" -DPACKAGE_TARNAME=\"mapguide\"
>>> -DPACKAGE_VERSION=\"2.0.0\" -DPACKAGE_STRING=\"mapguide\ 2.0.0\"
>>> -DPACKAGE_BUGREPORT=\"http://mapguide.osgeo.org\" -DPACKAGE=\"mapguide\"
>>> -DVERSION=\"2.0.0\" -DPACKAGE=\"mapguide\" -DVERSION=\"2.0.0\"
>>> -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1
>>> -DHAVE_STDLIB_H=1
>>> -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1
>>> -DHAVE_INTTYPES_H=1
>>> -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -DSTDC_HEADERS=1
>>> -DHAVE_UNISTD_H=1 -DHAVE_MATH_H=1 -DHAVE_NETDB_H=1 -DHAVE_NETINET_IN_H=1
>>> -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_SOCKET_H=1 -DHAVE_GETHOSTBYNAME=1
>>> -DHAVE_SOCKET=1 -DHAVE_HTONS=1 -DHAVE_CONNECT=1 -DHAVE_SHUTDOWN=1  -I.
>>> -I.
>>> -I../MdfModel/ -I../Foundation -I/usr/local/fdo-3.4.0/include
>>> -I/usr/local/fdo-3.4.0/include/ExpressionEngine
>>> -I../../Oem/ACE/ACE_wrappers
>>> -O2 -g -pipe -march=i386 -mcpu=i686 -fno-use-cxa-atexit -fexceptions -MT
>>> Band.lo -MD -MP -MF ".deps/Band.Tpo" -c -o Band.lo Band.cpp; \
>>>         then mv -f ".deps/Band.Tpo" ".deps/Band.Plo"; else rm -f
>>> ".deps/Band.Tpo"; exit 1; fi
>>>  g++ -DPACKAGE_NAME=\"mapguide\" -DPACKAGE_TARNAME=\"mapguide\"
>>> -DPACKAGE_VERSION=\"2.0.0\" "-DPACKAGE_STRING=\"mapguide 2.0.0\""
>>> -DHAVE_STDLIB_H=1
>>> -DHAVE_INTTYPES_H=1
>>> -DHAVE_SOCKET=1 -DHAVE_HTONS=1 -DHAVE_CONNECT=1 -DHAVE_SHUTDOWN=1 -I. -I.
>>> Band.lo -MD -MP -MF .deps/Band.Tpo -c Band.cpp  -fPIC -DPIC -o
>>> .libs/Band.o
>>> `-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.
>>> In file included from Band.h:21,
>>>                  from Band.cpp:20:
>>> Stylization.h:78:33: error: FdoExpressionEngine.h: No such file or
>>> directory
>>> Stylization.h:79:51: error: FdoExpressionEngineFunctionCollection.h: No
>>> such
>>> file or directory
>>> Stylization.h:80:54: error: FdoExpressionEngineINonAggregateFunction.h:
>>> No
>>> such file or directory
>>> make[2]: *** [Band.lo] Error 1
>>> make[2]: se sale del directorio `/tmp/mgos21/MgDev/Common/Stylization'
>>> make[1]: *** [all-recursive] Error 1
>>> make[1]: se sale del directorio `/tmp/mgos21/MgDev/Common'
>>> make: *** [all-recursive] Error 1
>>> Any Idea?
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090226/051e2e2b/attachment.html
