[mapguide-users] problem building mapguide from svn
alucas
alucas at svl.es
Thu Feb 26 09:41:25 EST 2009
This can explain the problem... :-)
Thanks.
Jack Lee-3 wrote:
> Hi,
> There seems to some problems with the Linux sdk tar file. Some header
> files and libraries are missing.
> Until this is fixed, you would need to build and install Fdo.
> alucas wrote:
>> Hi Jackie,
>> I've installed the FDO 3.4.0 RC1 SDK for RHEL4. I didn't build it.
>> Thanks.
>> Jack Lee-3 wrote:
>>> Hi,
>>> Did you build and install Fdo?
>>> alucas wrote:
>>>> Hello,
>>>> I'm trying to build mapguide from svn and I'm getting this error in the
>>>> make
>>>> command:
>>>> make[2]: se ingresa al directorio
>>>> `/tmp/mgos21/MgDev/Common/Stylization'
>>>> if /bin/sh ../../libtool --tag=CXX --mode=compile g++
>>>> -DPACKAGE_NAME=\"mapguide\" -DPACKAGE_TARNAME=\"mapguide\"
>>>> -DPACKAGE_VERSION=\"2.0.0\" -DPACKAGE_STRING=\"mapguide\ 2.0.0\"
>>>> -DPACKAGE_BUGREPORT=\"http://mapguide.osgeo.org\"
>>>> -DPACKAGE=\"mapguide\"
>>>> -DVERSION=\"2.0.0\" -DPACKAGE=\"mapguide\" -DVERSION=\"2.0.0\"
>>>> -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1
>>>> -DHAVE_STDLIB_H=1
>>>> -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1
>>>> -DHAVE_INTTYPES_H=1
>>>> -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1 -DSTDC_HEADERS=1
>>>> -DHAVE_UNISTD_H=1 -DHAVE_MATH_H=1 -DHAVE_NETDB_H=1
>>>> -DHAVE_NETINET_IN_H=1
>>>> -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_SOCKET_H=1 -DHAVE_GETHOSTBYNAME=1
>>>> -DHAVE_SOCKET=1 -DHAVE_HTONS=1 -DHAVE_CONNECT=1 -DHAVE_SHUTDOWN=1 -I.
>>>> -I.
>>>> -I../MdfModel/ -I../Foundation -I/usr/local/fdo-3.4.0/include
>>>> -I/usr/local/fdo-3.4.0/include/ExpressionEngine
>>>> -I../../Oem/ACE/ACE_wrappers
>>>> -O2 -g -pipe -march=i386 -mcpu=i686 -fno-use-cxa-atexit -fexceptions
>>>> -MT
>>>> Band.lo -MD -MP -MF ".deps/Band.Tpo" -c -o Band.lo Band.cpp; \
>>>> then mv -f ".deps/Band.Tpo" ".deps/Band.Plo"; else rm -f
>>>> ".deps/Band.Tpo"; exit 1; fi
>>>> g++ -DPACKAGE_NAME=\"mapguide\" -DPACKAGE_TARNAME=\"mapguide\"
>>>> -DPACKAGE_VERSION=\"2.0.0\" "-DPACKAGE_STRING=\"mapguide 2.0.0\""
>>>> -DHAVE_STDLIB_H=1
>>>> -DHAVE_INTTYPES_H=1
>>>> -I.
>>>> -MT
>>>> Band.lo -MD -MP -MF .deps/Band.Tpo -c Band.cpp -fPIC -DPIC -o
>>>> .libs/Band.o
>>>> `-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.
>>>> In file included from Band.h:21,
>>>> from Band.cpp:20:
>>>> Stylization.h:78:33: error: FdoExpressionEngine.h: No such file or
>>>> directory
>>>> Stylization.h:79:51: error: FdoExpressionEngineFunctionCollection.h: No
>>>> such
>>>> file or directory
>>>> Stylization.h:80:54: error: FdoExpressionEngineINonAggregateFunction.h:
>>>> No
>>>> such file or directory
>>>> make[2]: *** [Band.lo] Error 1
>>>> make[2]: se sale del directorio `/tmp/mgos21/MgDev/Common/Stylization'
>>>> make[1]: *** [all-recursive] Error 1
>>>> make[1]: se sale del directorio `/tmp/mgos21/MgDev/Common'
>>>> make: *** [all-recursive] Error 1
>>>> Any Idea?
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/problem-building-mapguide-from-svn-tp2385016p2389989.html
