[mapguide-users] DigitizePolygon
Paul Spencer pagameba at gmail.com
Mon Jan 5 10:43:25 EST 2009
I think you have bypassed something critical in the process, but I'm
not sure.  When the digitize functions are used, something needs to
tell the digitized features that the extent has changed so they can
redraw themselves.  It should happen automatically by something
registering for an event on the map, so something about how you've
implemented it is probably bypassing this part.  Unfortunately I
haven't used this at all so I can't really help much with debugging.
Perhaps Chris or Mike could comment?
Paul
On 4-Jan-09, at 6:35 PM, Mark Pendergraft wrote:
> I have some questions about this function provided in the
> MapGuideViewerApi.js file.  I was wondering if anyone else is using
> this function and if they have any issues with panning and or
> zooming while the user is digitizing.  I'm calling the function from
> a widget and panning/zooming and refreshing the map all cause it to
> break.  I'm curious if this is an issue with my widget not telling
> Fusion that it's active, or (the less likely of the two) if these
> actions were overlooked when the function was designed.
> Thanks for the help
> -Mark Pendergraft
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
