[mapguide-users] create a temporary !Mapdefinition and add a layer
Arnaud De Groof
Arnaud.DeGroof at spacebel.be
Tue Jan 6 10:07:04 EST 2009
OK, in fact my comprehension of the "target" was incorrect. It was not necessary to use the target to view the new temporary Weblayout; a simple refresh allows it.
Is it possible to refresh directly the viewer by adding a line in the php code? I saw a RefreshMap.js.
Regards,
Arnaud De Groof
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth Skovhede, GEOGRAF A/S
Sent: mardi 6 janvier 2009 13:58
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] create a temporary !Mapdefinition and add a layer
The "Target" stuff refers to clicking on a link on a feature.
The PHP code below only relocates the current page.
This means that the new window is created *before* the
code below is being run. Try locating that spot,
and change the target to "_top" or "_self".
For explanation on the targets, look here:
http://www.codetoad.com/html/frames/specifying_frames.asp
If you are actually modifying the WebLayout when clicking a feature,
the target should probably be set to "_parent" in Maestro.
After setting the target, press the "View Xml" button to
see what changes your code has to make to achieve the same.
Regards, Kenneth Skovhede, GEOGRAF A/S
Arnaud De Groof skrev:
Hi Kenneth,
Thanks to your precisions, all the code is correct.
I have a specific question. The new temporary WebLayout appears in a new window. Is it possible to update only the current viewer with this new temporary WebLayout? I don't find specific command in Maestro for it.
Invoke URL command:
-> Extra properties
Target :
* NewWindow = WebLayout in a new window
* SpecifiedFrame = WebLayout in a new window (I have used the "id" of the Viewer Frame)
* TaskPane = WebLayout in the Taskpane
Thanks
Arnaud De Groof
The new code:
<?php
// Vital includes.
include "../../mapviewerphp/constants.php";
include "../../mapviewerphp/common.php";
$args = ($_SERVER['REQUEST_METHOD'] == "POST") ? $_POST : $_GET;
$sessionId = $args['SESSION'];
$mapName = $args['MAPNAME'];
$layerName1 = 'YYY';
$rlLayerResourceId = "Library://XXX/$layerName1.LayerDefinition";
InitializeWebTier();
$userInfo = new MgUserInformation($sessionId);
$siteConnection = new MgSiteConnection();
$siteConnection->Open($userInfo);
$resourceService = $siteConnection->CreateService(MgServiceType::ResourceService);
// Read the MapDefinition into an XML DOM document object.
$md = " Library://XXX/$mapName.MapDefinition "; // TODO Constant!
$mdResourceId = new MgResourceIdentifier($md);
$mdReader = $resourceService->GetResourceContent($mdResourceId);
$mdXml = $mdReader->ToString();
$mdDomDoc = DOMDocument::loadXML($mdXml);
// Add a new MapLayer
$targetNode = $mdDomDoc->getElementsByTagName("MapLayer")->item(0);
$newNode = $targetNode->parentNode->insertBefore(new DOMElement("MapLayer"), $targetNode);
$newNode->appendChild($mdDomDoc->createElement("Name", $layerName1));
$newNode->appendChild($mdDomDoc->createElement("ResourceId", $rlLayerResourceId));
$newNode->appendChild($mdDomDoc->createElement("Selectable", "false"));
$newNode->appendChild($mdDomDoc->createElement("ShowInLegend", "false"));
$newNode->appendChild($mdDomDoc->createElement("LegendLabel"));
$newNode->appendChild($mdDomDoc->createElement("ExpandInLegend", "false"));
$newNode->appendChild($mdDomDoc->createElement("Visible", "true"));
$newNode->appendChild($mdDomDoc->createElement("Group"));
// Save the updated MapDefinition
$updatedXml = $mdDomDoc->saveXML();
$byteSource = new MgByteSource($updatedXml, strlen($updatedXml));
// Create the temporary MapDefinition
$sessionMapName = $mdResourceId->GetName();
$sessionMapDefinition = "Session:$sessionId//$sessionMapName.MapDefinition";
$sessionResourceId = new MgResourceIdentifier($sessionMapDefinition);
// Write the updated MapDefinition
$resourceService->SetResource($sessionResourceId, $byteSource->GetReader(), null);
//Test the updated MapDefinition
$md1 = "Session:$sessionId//X.MapDefinition";
$mdResourceId2 = new MgResourceIdentifier($md1);
$mdReader2 = $resourceService->GetResourceContent($mdResourceId2);
$mdXml2 = $mdReader2->ToString();
$mdDomDoc2 = DOMDocument::loadXML($mdXml2);
// Read the WebLayout into an XML DOM document object.
$wl = "Library://XXX/XXX.WebLayout"; // TODO Constant!
$wlResourceId = new MgResourceIdentifier($wl);
$wlReader = $resourceService->GetResourceContent($wlResourceId);
$wlXml = $wlReader->ToString();
$wlDomDoc = DOMDocument::loadXML($wlXml);
// Now, update the MapDefinition.
$mapdef = $wlDomDoc->getElementsByTagName("ResourceId")->item(0);
$mapdef->nodeValue = "$md1";
// Prepare the updated XML to be written out to the session.
$wlupdatedXml = $wlDomDoc->saveXML();
$wlbyteSource = new MgByteSource($wlupdatedXml, strlen($wlupdatedXml));
// Create a temporary WebLayout
$wlsessionMapName = $wlResourceId->GetName();
$wlsessionWebLayout = "Session:$sessionId//$wlsessionMapName.WebLayout";
$wlsessionResourceId = new MgResourceIdentifier($wlsessionWebLayout);
// Write the updated WebLayout to the session.
$resourceService->SetResource($wlsessionResourceId, $wlbyteSource->GetReader(), null);
// Redirect to the Ajax viewer.
$redirectTo = "mapguide/mapviewerajax/?SESSION=$sessionId&WEBLAYOUT=$wlsessionWebLayout";
$host = $_SERVER["HTTP_HOST"];
$url = "http://$host/$redirectTo";
//Test
$f = 'test.txt';
$handle = fopen($f,"w");
fwrite($handle, "test1:<".$mdXml.">\r\ntest 2 :<".$updatedXml.">\r\ntest 3 :<".$wlXml.">\r\ntest 4 :<".$wlupdatedXml.">\r\ntest 5 :<".$url.">");
fclose($handle);
// Redirect!
header("Location: $url");
exit;
Sent: dimanche 28 décembre 2008 12:34
You must also make a temporary WebLayout.
This WebLayout must then point to the temporary MapDefinition.
In one of the last lines, you redirect to the temporary WebLayout.
If that temporary WebLayout points to the temporary MapDefinition,
all should be good. (Assuming layer is visible, in range, on top, etc.).
I have found my error. In fact, I used the command "SetRessource" with a WebLayout in place of a MapDefinition. Now the script seems ok.
How to load the WebLayout with the new MapDefinition (with the new layer) and not the MapDefinition coming from the library (without the new layer)?
New code:
<?php
// Initialize
MgInitializeWebTier($webconfigFilePath);
// Build a string pointing to the new layer in the Session
$rlLayerResourceId = "Session:$sessionId//$layerName1.LayerDefinition";
// Read the XML of the Library Map Definition
$md ="Library://XXX/$mapName.MapDefinition";
// Insert the layer in the MapDefinition
// Write the XML out to form the Session MapDefinition
// Create a new MapDefinition (session repository).
// Test the new MapDefinition
$mdtest = "Session:$sessionId///$mapName.MapDefinition";
$mdResourceIdtest = new MgResourceIdentifier($mdtest);
$mdReadertest = $resourceService->GetResourceContent($mdResourceIdtest);
$mdXmltest = $mdReader2->ToString();
$mdDomDoctest = DOMDocument::loadXML($mdXmltest);
// Redirect to the Ajax viewer pointing at the map at the desired coordinates.
$redirectTo = "mapguide/mapviewerajax/?WEBLAYOUT=$sessionWebLayout&SESSION=$sessionId";
$url = "http://$host/$redirectTo" <http://$host/$redirectTo> ;
// Redirect!
exit;
Thanks,
Arnaud De Groof
Sent: mardi 23 décembre 2008 8:15
The previous error you had indicated that the xml was invalid.
This is likely because you are not sending the entire xml document to the server.
Perhaps someone with better PHP skills can help you out.
I have changed the line: "$byteSource = new MgByteSource($updatedXml, strlen($updatedXml));" by "$byteSource = new MgByteSource($updatedXml, mb_strlen($updatedXml));" without success.
The xml code coming from the initial MapDefinition was carried out thanks to Maestro. I join here the result of the $updatedXml:
<?xml version="1.0" encoding="utf-8"?>
<MapDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" <http://www.w3.org/2001/XMLSchema-instance> xmlns:xsd="http://www.w3.org/2001/XMLSchema" <http://www.w3.org/2001/XMLSchema> xsi:noNamespaceSchemaLocation="MapDefinition-1.0.0.xsd">
<Name>New Map</Name>
<CoordinateSystem>PROJCS["WGS 84 / UTM zone 48N",GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",105],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AUTHORITY["EPSG","32648"]]</CoordinateSystem>
<Extents>
<MinX>608404.999984747</MinX>
<MaxX>641160.000015253</MaxX>
<MinY>1121406.87752137</MinY>
<MaxY>1142427.99990895</MaxY>
</Extents>
<BackgroundColor>ffffffff</BackgroundColor>
<Metadata/>
<MapLayer><Name>YYY</Name><ResourceId>Session:92b640a0-ffff-ffff-8002-001aa0d22567_fr_7F0000010AFC0AFB0AFA// YYY.LayerDefinition</ResourceId><Selectable>false</Selectable><ShowInLegend>false</ShowInLegend><LegendLabel/><ExpandInLegend>false</ExpandInLegend><Visible>true</Visible><Group/></MapLayer><MapLayer>
<Name>Station</Name>
<ResourceId>Library://XXX/Station.LayerDefinition</ResourceId>
Thanks for your help.
Regards,
Arnaud De Groof
<hr size=2 width="100%" align=center>
E-MAIL DISCLAIMER
The present message may contain confidential and/or legally privileged information. If you are not the intended addressee and in case of a transmission error, please notify the sender immediately and destroy this E-mail. Disclosure, reproduction or distribution of this document and its possible attachments is strictly forbidden.
SPACEBEL denies all liability for incomplete, improper, inaccurate, intercepted, (partly) destroyed, lost and/or belated transmission of the current information given that unencrypted electronic transmission cannot currently be guaranteed to be secure or error free.
Upon request or in conformity with formal, contractual agreements, an originally signed hard copy will be sent to you to confirm the information contained in this E-mail.
SPACEBEL denies all liability where E-mail is used for private use.
SPACEBEL cannot be held responsible for possible viruses that might corrupt this message and/or your computer system.
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090106/6ba738e6/attachment.html
