[ZS2] [mapguide-users] Data *.csv on maestro
Dave Wilson dave.wilson at autodesk.com
Tue Jan 6 18:41:12 EST 2009
Based on testing. There is a problem in the provider from what I can see, but I have no idea what the issue is.
Dave
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth Skovhede, GEOGRAF A/S
Sent: Tuesday, January 06, 2009 4:16 PM
To: MapGuide Users Mail List
Subject: Re: [ZS2] [mapguide-users] Data *.csv on maestro
Is that based on testing, or do you know that it does not work?
If so, do you know the reason?
Regards, Kenneth Skovhede, GEOGRAF A/S
Dave Wilson skrev:
I think you will find that text or csv based ODBC sources do not work.
Regards,
Dave
From: mapguide-users-bounces at lists.osgeo.org<mailto:mapguide-users-bounces at lists.osgeo.org> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth Skovhede, GEOGRAF A/S
Sent: Tuesday, January 06, 2009 1:45 PM
What connection string is created?
Mine looks like this:
Driver={Microsoft Text Driver (*.txt; *.csv)};Dbq=C:\test.csv;Extensions=asc,csv,tab,txt;Uid=;Pwd=
ajid skrev:
http://n2.nabble.com/file/n2116232/001.jpg
My Prob / Error
When I Test Connection d error >>
The remote server returned an error: (559) MgFdoException.:
An exception occurred in FDO component.
RDBMS: No current open database.
Exception occurred in method MgFdoConnectionManager.Open at line 858 in file
Anyone can tech me how??
i used this technique
You need to do this:
1. Click "New"
2. Select "Dataconnection"
3. Select "OSGeo FDO provider for ODBC"
4. Select "File on the server (Unmanaged)"
5. Type the path to the .csv file
But Failed..
Yazid Yusof
Mapping and Graphic Department
www.sapura.com.my<http://www.sapura.com.my>
mapguide-users mailing list
mapguide-users at lists.osgeo.org<mailto:mapguide-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090106/3f6489d9/attachment.html
