[mapguide-users] Mapguide opensource very unstable problem
marius.360 marius at osssa.co.za
Tue Jan 6 00:46:34 EST 2009
Hi all,
I have a situation where my mapguide opensource setup crashes on a regular
basis. In the past this only happened about once a week, but it is occuring
on a more regular basis, at least once a day.
All my spatial and attribute data is in an Oracle 10gR2 database version
10.2.0.1 and I am using the latest FdoKingOracle v0_8_5 provider. The server
is a Windows Server 2003 service pack 2 setup, with Mapguide Opensource
2.0.2. The DWF viewer is being used to display the map. There are quite a
few active users on the system, around 50.
When this problem occurs and I open the map, only a grey screen will display
and sometimes there will be a message that says "Not connected to oracle".
Here are two of the error messages that are created when this problem
occurs:
"<2008-12-19T09:55:31> 		192.168.104.33	Anonymous
 Error: Failed to stylize layer: NEURON_ROD
        An exception occurred in FDO component.
        ORA-03114: not connected to ORACLE
 StackTrace:
  - MgMappingUtil.StylizeLayers line 786 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\mapping\MappingUtil.cpp
"<2008-12-24T11:28:57> 		192.168.105.54	Anonymous
 Error: An unclassified exception occurred.
 StackTrace:
  - MgFeatureServiceHandler.ProcessOperation line 83 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
  - MgOpGetIdentityProperties.Execute line 113 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\OpGetIdentityProperties.cpp
  - MgServerDescribeSchema.GetIdentityProperties line 1715 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\ServerDescribeSchema.cpp
  - MgServerDescribeSchema.ExecuteDescribeSchema line 176 file
An unclassified exception occurred."
Please let me know if you require any more info, I will gladly provide it as
this is a major problem for me.
Kind Regards,
Marius
View this message in context: http://n2.nabble.com/Mapguide-opensource-very-unstable-problem-tp2116397p2116397.html
