[mapguide-users] ASP .Net Digitize examples Draw Line and Draw Polygon
Jamo
adam.jamison at portbris.com.au
Wed Jan 7 18:12:13 EST 2009
Gday I've been trying to help Padmini understand some of the digitize
functions I've partly written for the ASP .Net Mapguide thought I might
share our discussion as other might benefit from it or perhaps others could
check the code for errors ... I'm still learning here as well so nothing
here is set in stone!
I've uploaded some datafiles. Extract it to mapguide / enterprise Directory
(C:\Program Files\MapGuideOpenSource2.0\)
After this you will need to load the mgp in site administrator it will give
a Test\Padmnin\ directory under your library and extract some aspx files to
your www\Test\Padmini\
Check the custom Invoke script commands and there extra properties for how
coordinates are transfered to the code :)
These files are as I have been writting them might be a little messy%-|
http://n2.nabble.com/file/n2125282/PadminiToolset.rar PadminiToolset.rar
I have started to write other digitize commands for points, text and style
of all types, but There still in progress.
View this message in context: http://n2.nabble.com/ASP-.Net-Digitize-examples-Draw-Line-and-Draw-Polygon-tp2125282p2125282.html
