[mapguide-users] ASP .Net Digitize examples Draw Line and Draw
Polygon
Jackie Ng
jumpinjackie at gmail.com
Wed Jan 7 22:38:32 EST 2009
Thanks for sharing the code.
You should put this in the code samples too
http://trac.osgeo.org/mapguide/wiki/CodeSamples
- Jackie
Jamo wrote:
> Gday I've been trying to help Padmini understand some of the digitize
> functions I've partly written for the ASP .Net Mapguide thought I might
> share our discussion as other might benefit from it or perhaps others
> could check the code for errors ... I'm still learning here as well so
> nothing here is set in stone!
> I've uploaded some datafiles. Extract it to mapguide / enterprise
> Directory (C:\Program Files\MapGuideOpenSource2.0\)
> After this you will need to load the mgp in site administrator it will
> give a Test\Padmnin\ directory under your library and extract some aspx
> files to your www\Test\Padmini\
> Check the custom Invoke script commands and there extra properties for how
> coordinates are transfered to the code :)
> These files are as I have been writting them might be a little messy%-|
> http://n2.nabble.com/file/n2125282/PadminiToolset.rar PadminiToolset.rar
> I have started to write other digitize commands for points, text and style
> of all types, but There still in progress.
View this message in context: http://n2.nabble.com/ASP-.Net-Digitize-examples-Draw-Line-and-Draw-Polygon-tp2125282p2126212.html
