[mapguide-users] ASP .Net Digitize examples Draw Line and Draw
Polygon
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Thu Jan 8 04:28:30 EST 2009
Hi Jamo.
Thanks for sharing!
There exists a place for contributed code like that:
http://trac.osgeo.org/mapguide/wiki/CodeSamples
If you have the time, could you please add the code there, so
it can be easily found later?
Regards, Kenneth Skovhede, GEOGRAF A/S
Jamo skrev:
> Gday I've been trying to help Padmini understand some of the digitize
> functions I've partly written for the ASP .Net Mapguide thought I might
> share our discussion as other might benefit from it or perhaps others could
> check the code for errors ... I'm still learning here as well so nothing
> here is set in stone!
> I've uploaded some datafiles. Extract it to mapguide / enterprise Directory
> (C:\Program Files\MapGuideOpenSource2.0\)
> After this you will need to load the mgp in site administrator it will give
> a Test\Padmnin\ directory under your library and extract some aspx files to
> your www\Test\Padmini\
> Check the custom Invoke script commands and there extra properties for how
> coordinates are transfered to the code :)
> These files are as I have been writting them might be a little messy%-|
> http://n2.nabble.com/file/n2125282/PadminiToolset.rar PadminiToolset.rar
> I have started to write other digitize commands for points, text and style
> of all types, but There still in progress.
