[mapguide-users] Adding OpenLayers.Layer to Fusion Map
Mark Pendergraft markp at Meadgilman.com
Thu Jan 8 11:38:36 EST 2009
I wasn't adding the layer switcher to my map because I had hoped to add
the layers in the Legend Widget.  When I add the LayerSwitcher Google
layers show up, but they are zoomed to the extent of the entire map (aka
entire world).
I would pursue setting them at the correct extents, but Paul informs me
that Fusion 2.0 Beta will be arriving shortly with support for any
OpenLayers Layer type.  I have a lot of work to do on my Fusion map in
the meantime so I'll put this off until the Beta comes out.
Thanks for your help.
-Mark P.
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Wednesday, January 07, 2009 5:32 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Adding OpenLayers.Layer to Fusion Map
your going to need to dive into the whole projection and OL spherical
mercator stuff
I'm prety sure the google layers will be added as what's called a base
layer in OL which means
they won't be displayed by default
does the layer switcher show up?
z
On Thu, Jan 8, 2009 at 7:27 AM, Mark Pendergraft <markp at meadgilman.com>
wrote:
> I would like to add an OpenLayers.Layer (specifically google maps) to
my
> MGOS Fusion Layout.  I've been looking through the posts and there is
a lot
> of info regarding both of these but I'm at a loss as to how to
implement it
> with Fusion.
> I can get the OpenLayers map using the following code
> var mapWidget = Fusion.getWidgetById('Map');
> var olmap = mapWidget.oMapOL;
> and on a separate page that I made I can implement google into
openlayers
> using the following script:
> map = new OpenLayers.Map('map');
>             map.addControl(new OpenLayers.Control.LayerSwitcher());
>             var gphy = new OpenLayers.Layer.Google(
>                 "Google Physical",
>                 {type: G_PHYSICAL_MAP}
>             var gmap = new OpenLayers.Layer.Google(
>                 "Google Streets", // the default
>                 {numZoomLevels: 20}
>             var ghyb = new OpenLayers.Layer.Google(
>                 "Google Hybrid",
>                 {type: G_HYBRID_MAP, numZoomLevels: 20}
>             var gsat = new OpenLayers.Layer.Google(
>                 "Google Satellite",
>                 {type: G_SATELLITE_MAP, numZoomLevels: 20}
>             map.addLayers([gphy, gmap, ghyb, gsat]);
>             map.setCenter(new OpenLayers.LonLat(10.2, 48.9), 5);
> But I'm not sure how to implement both together.  When I add the
google
> layers to the olMap, nothing breaks but my normal Fusion layout shows
up.
> I'm looking for a push in the right direction here, or a link to an
example
> that I can explore.  The end goal is to have my normal Fusion map with
> google as a layer which can be turned on/off in the legend widget.
> I'm assuming that I will have to access openlayers via
> Fusion.getWidgetById('Map').olMap; and add the openlayers.layer to the
> olMap.  But then how do I register those layers with the mapWidget in
order
> for them to show up.  Also, I'm assuming that I will have to set some
type
> of bounds or coordinate conversion for the google layers to know where
they
> are on my map, seeing as my map is on a state plane coordinate system
> instead of lat/long.
> Thanks for the help
> -Mark P.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
