[mapguide-users] no MapGuideJavaApi in java.library.path
Riccardo Pucci
riccardo.pucci at gruppoesc.it
Thu Jan 8 11:33:08 EST 2009
I think that problem is in the name: in Linux system, JNI search for
something named libMapGuideJavaApi.so, and that file should be found in
the library path, while in windows system it search for
MapGuideJavaApi.dll. You may try to make a symbolic link to the object
created by build system named libMapGuideJavaApi.so
The easiest way to put a library in the library path is to ensure that
the directory where is located is in the system path.
Hope this helps
Riccardo
gimbrogno @smartlab ha scritto:
> Hi, I have installed Mapguide OpenSource on same linux systems (ubuntu 7.10
> and CentOS 5.1), but I have an error zwhen try the java sample !!!
> When LinuxApt is compiled, it is not able to create the MapGuideApi.jar, so
> I have copied this jar from a windows in /WEB-INF/lib.
> Unber the directory tomcat/conf there is not Catalina/localhost, so I have
> created this two directories and I've copied the LinuxApt/mapguide.xml into.
> After these works the result page is "no MapGuideJavaApi in
> java.library.path... ", but MapGuideJavaApi is not a jar file but a static
> object (MapGuideJavaApi.so.0.7). Where is the library path where this object
> must be copied to?
> Under windows systems, I have no problems!!! There is anyone that uses
> MaGuide OpenSource under Linux that can helps me?
> Thanks in advantage... (I'm sorry for my english, but english is not my
> native language)
