[mapguide-users] King.Oracle provider
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Jan 15 15:50:07 EST 2009
Alright, thanks for trying that out.
I must have some strangenes in my datasource then.
Regards, Kenneth Skovhede, GEOGRAF A/S
Simon Pelicon skrev:
> I could 't repeat this issue with and King.Oracle 0.8.5 provider and
> MGOS 2.0.2.
> Testing http://localhost/mapguide/mapagent/selectfeaturesform.html
> with different FDO classes and different filter string like (
> OBJECT_ID >= 30919 ) or(  OBJECT_ID >= 30919 AND PARENT_ID= 10 )
> i get correct results.
> Using "=>" returns FDO exception  "String does not represent a valid
> filter" so you should use ">="
> Simon
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> I was testing the King.Oracle 0.8.5 provider, using the standard form:
>> Using the previous version (the one included in FDO 3.3.1 / MGOS 2.0.2),
>> I could not get it to return any feature if I entered a non-trivial
>> filter like:
>> ID => 0 or ID <= 0
>> The filter 1=1 seems to work though.
>> The updated version seems to have trouble if I specify a column.
>> Specifying no columns seems to revert to the previous behavior.
>> Is this a known issue or limitiation?
>> No virus found in this incoming message.
>> Checked by AVG - http://www.avg.com
>> Version: 8.0.176 / Virus Database: 270.10.5/1881 - Release Date: 7.1.2009 17:59
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090115/9cdeb285/attachment.html
