[mapguide-users] Session Map and Settings Serverside
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Jan 8 16:48:55 EST 2009
No, that value is only present in the client.
It would be difficult to detect the scale value if you were drawing
multiple maps,
eg. a "real" map, a print preview and an overview map.
Regards, Kenneth Skovhede, GEOGRAF A/S
Rock Beans skrev:
> Thanks I got the layer control figured out now. I wish you could set
> the map.viewscale= is the only thing. I would still have to do a
> Javascript refresh. So this ZoomToView(x, y, scale, refresh) might be
> just as good either way. Is there a way to set the scale serverside
> using the map object?
> Thanks!
> On Thu, Jan 8, 2009 at 3:39 PM, Kenneth Skovhede, GEOGRAF A/S
> <ks at geograf.dk> wrote:
>> What do you mean when you say that "visible" is read only?
>> You can use the "getVisible()" and "setVisible()" functions to set layer
>> visibility.
>> An example here:
>> http://discussion.autodesk.com/forums/thread.jspa?threadID=629000&tstart=75
>> The "Session:xxx//MapName.Map" is an almost empty placeholder document.
>> The document has a binary object attached, which is what you modify with
>> operations like the above.
>> You probably don't want to go there.
>> AFAIK, the map center and scale values are only stored in the client (aka:
>> javascript).
>> So you have to use the Viewer API to get/set those values.
>> (The DWF viewer may be different)
>> Rock Beans skrev:
>>> I can use the API to get layer information like what is turned on and
>>> off but I can't set visible since it is read only. It would be nice if
>>> you could just make the changes there save and issue a javascript map
>>> refresh. What is the best method for remembering the last location
>>> viewed and returning to the location with a click of a button. I
>>> really want to stay away from the viewer API if at all possible except
>>> for the refresh of course.
>>> I first thought I could just go layer.visible=false... no go
>>> Then I played with Session:xxx//MapName.Map with SetResource... is
>>> this the best route?
>>> Any ideas?
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090108/a98fabc1/attachment.html
