[mapguide-users] Session Map and Settings Serverside
Rock Beans
rockbeans at gmail.com
Thu Jan 8 17:11:40 EST 2009
Is there a GetLegendFrame() viewer command? There seems to be one for
everything else. I need to refresh Legend and I don't want to hard
code but if needed will do. I got the map doing what I want with
layers and scale. Then call ZoomToView with refresh = true. That
should in my mind refresh the legend tooooooo. Why does it not?
On Thu, Jan 8, 2009 at 3:48 PM, Kenneth Skovhede, GEOGRAF A/S
<ks at geograf.dk> wrote:
> No, that value is only present in the client.
> It would be difficult to detect the scale value if you were drawing multiple
> maps,
> eg. a "real" map, a print preview and an overview map.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Rock Beans skrev:
> Thanks I got the layer control figured out now. I wish you could set
> the map.viewscale= is the only thing. I would still have to do a
> Javascript refresh. So this ZoomToView(x, y, scale, refresh) might be
> just as good either way. Is there a way to set the scale serverside
> using the map object?
> Thanks!
> On Thu, Jan 8, 2009 at 3:39 PM, Kenneth Skovhede, GEOGRAF A/S
> What do you mean when you say that "visible" is read only?
> You can use the "getVisible()" and "setVisible()" functions to set layer
> visibility.
> An example here:
> http://discussion.autodesk.com/forums/thread.jspa?threadID=629000&tstart=75
> The "Session:xxx//MapName.Map" is an almost empty placeholder document.
> The document has a binary object attached, which is what you modify with
> operations like the above.
> You probably don't want to go there.
> AFAIK, the map center and scale values are only stored in the client (aka:
> javascript).
> So you have to use the Viewer API to get/set those values.
> (The DWF viewer may be different)
> Rock Beans skrev:
> I can use the API to get layer information like what is turned on and
> off but I can't set visible since it is read only. It would be nice if
> you could just make the changes there save and issue a javascript map
> refresh. What is the best method for remembering the last location
> viewed and returning to the location with a click of a button. I
> really want to stay away from the viewer API if at all possible except
> for the refresh of course.
> I first thought I could just go layer.visible=false... no go
> Then I played with Session:xxx//MapName.Map with SetResource... is
> this the best route?
> Any ideas?
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
