[mapguide-users] Mapguide on a CD ?
Zac Spitzer
zac.spitzer at gmail.com
Thu Jan 8 21:48:25 EST 2009
there is already a mapguide live cd with 2.0.1 on ubuntu
http://mapguide.osgeo.org/node/127
z
On Fri, Jan 9, 2009 at 1:35 PM, Jamo <adam.jamison at portbris.com.au> wrote:
> Just Curious at the moment, I'm looking at ways of giving users the ability
> to use mapguide from a CD ?
> It would have to run under Windows not a live boot .....
> I've found This information which sort of helps....? has anyone tried this
> before?
> http://www.wellho.co.uk/solutions/general-windows-running-apache-and-mysql-from-a-cd.html
> I would settle for a USB Flash drive that can read / write data...
> I'm guessing I need to change some variables in the serverconfig.ini and
> httpd.conf(Anyone know what I might need to change) ? I've also seen some
> mods to the apache server that allow ASP .Net to run under it :) This will
> make things a little easier as I've been writting in ASP .Net thus far :)
> Basically thinking about field reports and the like, I'd like to be able to
> load a series of SDFs onto a flash drive and let the user go out in the
> field with a gps unit, find where they are and see there location in
> mapguide (basically trying to keep the interface the user is using the same
> throughout rather than bring in tons of different apps), create some forms
> that the user can edit data in the SDF then when they come back batch update
> the information that has been changed :) ....
> This is a long way away but knowing it's possible is always good to keep in
> the back of my head ....
> View this message in context: http://n2.nabble.com/Mapguide-on-a-CD---tp2131494p2131494.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
