[mapguide-users] mutiple layers against single feature source
Atika Irfan
irfan.atika at gmail.com
Fri Jan 9 05:48:55 EST 2009
thanks a lot for the reply ....so if we have a single database then we
should have mutiple datasources aginst it & then mutiple feature sources
which relate to a layer individually ... do you think server crashing might
be related to this issue ?
On Fri, Jan 9, 2009 at 3:45 PM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> theming into a single layer is more efficient than filtering into lots of
> layers
> On Fri, Jan 9, 2009 at 9:35 PM, Atika Irfan <irfan.atika at gmail.com> wrote:
> > hi,
> > can we have mutiple layers against single feature source ..i mean that we
> > pull all the data from the database using one feature source then split
> it
> > to make mutiple layers by applying filters is it a fine or we should have
> > seperate feature source against each layer...... it looks like its
> crashing
> > the server ...any help?
> > mapguide-users mailing list
> > mapguide-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer -
> http://zacster.blogspot.com
> +61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090109/9dc2d737/attachment.html
