[mapguide-users] mutiple layers against single feature source
Zac Spitzer zac.spitzer at gmail.com
Fri Jan 9 06:00:34 EST 2009
the server shouldn't crash, it should just be slower, tho with a database
the filtering should peform better than sdf/shp which only have a spatial index
anything showing up in the error log? r u using 2.0.2? which db?
z
On Fri, Jan 9, 2009 at 9:48 PM, Atika Irfan <irfan.atika at gmail.com> wrote:
> thanks a lot for the reply ....so if we have a single database then we
> should have mutiple datasources aginst it & then mutiple feature sources
> which relate to a layer individually ... do you think server crashing might
> be related to this issue ?
> On Fri, Jan 9, 2009 at 3:45 PM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
>> theming into a single layer is more efficient than filtering into lots of
>> layers
>> On Fri, Jan 9, 2009 at 9:35 PM, Atika Irfan <irfan.atika at gmail.com> wrote:
>> > hi,
>> > can we have mutiple layers against single feature source ..i mean that
>> > we
>> > pull all the data from the database using one feature source then split
>> > it
>> > to make mutiple layers by applying filters is it a fine or we should
>> > have
>> > seperate feature source against each layer...... it looks like its
>> > crashing
>> > the server ...any help?
>> > _______________________________________________
>> > mapguide-users mailing list
>> > mapguide-users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> Zac Spitzer -
>> http://zacster.blogspot.com
>> +61 405 847 168
Zac Spitzer -
+61 405 847 168
