[mapguide-users] Mapguide on a CD ?
Jason Birch Jason.Birch at nanaimo.ca
Fri Jan 9 11:24:22 EST 2009
No, you can run it from within VMWare Player:
http://www.vmware.com/products/player/
The required VMWare config is available in this directory:
http://download.osgeo.org/mapguide/livecd/
You would have to modify the LiveCD to contain your files though; I
doubt that this would be a reasonable solution for you.
MapGuide's a fairly heavy system to be running off a USB drive.  It
could technically be possible though, running the service from the
command line and with extensive changes to the config files.  Not
especially easy to manage if it is, as you don't have control over what
drive letter gets assigned to the USB drive.
Jo Cook has done some really neat work setting up GIS on a USB stick:
http://www.archaeogeek.com/blog/portable-gis/
Jason
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jamo
Sent: January-08-09 6:54 PM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Mapguide on a CD ?
I am looking at running from within windows....
By live cd on ubuntu that would require the system to boot up from cd
using
ubuntu ?
I have nothing against ubuntu or linux but I'm already stretching my
friendship with our it department... They will not allow various OS to
load
on any of our pcs...
zspitzer wrote:
> there is already a mapguide live cd with 2.0.1 on ubuntu
> http://mapguide.osgeo.org/node/127
> z
> On Fri, Jan 9, 2009 at 1:35 PM, Jamo <adam.jamison at portbris.com.au>
wrote:
>> Just Curious at the moment, I'm looking at ways of giving users the
>> ability
>> to use mapguide from a CD ?
>> It would have to run under Windows not a live boot .....
>> I've found This information which sort of helps....? has anyone tried
>> this
>> before?
http://www.wellho.co.uk/solutions/general-windows-running-apache-and-mys
ql-from-a-cd.html
>> I would settle for a USB Flash drive that can read / write data...
>> I'm guessing I need to change some variables in the serverconfig.ini
and
>> httpd.conf(Anyone know what I might need to change) ? I've also seen
some
>> mods to the apache server that allow ASP .Net to run under it :) This
>> will
>> make things a little easier as I've been writting in ASP .Net thus
far :)
>> Basically thinking about field reports and the like, I'd like to be
able
>> to
>> load a series of SDFs onto a flash drive and let the user go out in
the
>> field with a gps unit, find where they are and see there location in
>> mapguide (basically trying to keep the interface the user is using
the
>> same
>> throughout rather than bring in tons of different apps), create some
>> forms
>> that the user can edit data in the SDF then when they come back batch
>> update
>> the information that has been changed :) ....
>> This is a long way away but knowing it's possible is always good to
keep
>> in
>> the back of my head ....
>> View this message in context:
>> http://n2.nabble.com/Mapguide-on-a-CD---tp2131494p2131494.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer -
> http://zacster.blogspot.com
> +61 405 847 168
http://n2.nabble.com/Mapguide-on-a-CD---tp2131494p2131537.html
