[mapguide-users] Thematic Mapping
Chris Claydon chris.claydon at autodesk.com
Fri Jan 9 12:44:02 EST 2009
Most of the interesting code for the Theme sample is in the files thememain.aspx and classes/theme.aspx
Thememain.aspx handles most of the UI
Theme.aspx contains the methods to retrieve required information from MapGuide, and to generate the new themed layer.
The key method is ApplyTheme() which retrieves an existing MapGuide layer definition, removes the existing theme configuration, and replaces it with the one defined by the user. It then adds this new layer definition to the map so that it can be displayed.
I would highly recommend consulting the MapGuide Web Tier API documentation to help in understanding the code.
Chris.
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of padmini godavarthi
Sent: Thursday, January 08, 2009 11:54 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Thematic Mapping
iam using Mapguide opensource 2.0 (with .net 2.0 (C#) and IIS 5.1)
Now i want to do the thematic mapping based on parcel id programmetically.
i saw dotnetviewersample application (Theme)its working fine.
but i didn't get the flow of the concept
can any one plz tell me the procedure and explain the thematic concept in
dotnetviewer sample application so that it will be very helpful to me.
Thanks and Regards,
Padmini.
View this message in context: http://n2.nabble.com/Thematic-Mapping-tp2132051p2132051.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
