[mapguide-users] RE: Theme layer application - point feature layers
Chris Claydon
chris.claydon at autodesk.com
Fri Jan 9 13:53:24 EST 2009
The sample code generates <AreaRule> elements in a layer definition, and therefore applies only to polygon styles. It should be relatively easy to modify it to handle point layers and styles instead.
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Arnaud De Groof
Sent: Friday, January 09, 2009 2:49 AM
To: MapGuide Users Mail List
Subject: [mapguide-users] Theme layer application - point feature layers
Hello,
Is it possible to use the application "Theme Layer" with point feature layers? The code sample (phpviewersample/theme) allows only selecting the polygon feature layers.
Thanks,
Arnaud De Groof
E-MAIL DISCLAIMER
The present message may contain confidential and/or legally privileged information. If you are not the intended addressee and in case of a transmission error, please notify the sender immediately and destroy this E-mail. Disclosure, reproduction or distribution of this document and its possible attachments is strictly forbidden.
SPACEBEL denies all liability for incomplete, improper, inaccurate, intercepted, (partly) destroyed, lost and/or belated transmission of the current information given that unencrypted electronic transmission cannot currently be guaranteed to be secure or error free.
Upon request or in conformity with formal, contractual agreements, an originally signed hard copy will be sent to you to confirm the information contained in this E-mail.
SPACEBEL denies all liability where E-mail is used for private use.
SPACEBEL cannot be held responsible for possible viruses that might corrupt this message and/or your computer system.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090109/cbb97647/attachment.html
