[mapguide-users] RE: Theme layer application - point feature
layers
Arnaud De Groof
Arnaud.DeGroof at spacebel.be
Mon Jan 12 09:29:33 EST 2009
Thanks for this information; I have modified the file
(../phpviewersample/theme/classes/theme.php) according your remarks.
Now, I have the possibility to select the point layers. I changed also
the different reference to the <AreaRule> by <PointRule>. I do not know
if these changes are correct because I have a problem with this function
(polygon layers), see
http://lists.osgeo.org/pipermail/mapguide-users/2009-January/016202.html
Regards,
Arnaud De Groof
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Chris
Claydon
Sent: vendredi 9 janvier 2009 19:53
To: MapGuide Users Mail List
Subject: [mapguide-users] RE: Theme layer application - point feature
layers
The sample code generates <AreaRule> elements in a layer definition, and
therefore applies only to polygon styles. It should be relatively easy
to modify it to handle point layers and styles instead.
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Arnaud De
Groof
Sent: Friday, January 09, 2009 2:49 AM
Subject: [mapguide-users] Theme layer application - point feature layers
Hello,
Is it possible to use the application "Theme Layer" with point feature
layers? The code sample (phpviewersample/theme) allows only selecting
the polygon feature layers.
Thanks,
Arnaud De Groof
E-MAIL DISCLAIMER
The present message may contain confidential and/or legally privileged
information. If you are not the intended addressee and in case of a
transmission error, please notify the sender immediately and destroy
this E-mail. Disclosure, reproduction or distribution of this document
and its possible attachments is strictly forbidden.
SPACEBEL denies all liability for incomplete, improper, inaccurate,
intercepted, (partly) destroyed, lost and/or belated transmission of the
current information given that unencrypted electronic transmission
cannot currently be guaranteed to be secure or error free.
Upon request or in conformity with formal, contractual agreements, an
originally signed hard copy will be sent to you to confirm the
information contained in this E-mail.
SPACEBEL denies all liability where E-mail is used for private use.
SPACEBEL cannot be held responsible for possible viruses that might
corrupt this message and/or your computer system.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090112/f5a24307/attachment.html
