[mapguide-users] RE: MapGuide API Intellisense in Visual Studio
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Mon Jan 12 06:30:39 EST 2009
AFAIK, the only difference between using codebehind and the "old-style"
asp tags,
is that the codebehind is precompiled, whereas the "old-style" tags are
compiled on the first access.
AFAIK, Microsoft recommends using codebehind, but the ASPX example was
meant to
be easy to look at and experiment with, which is possible in the current
setup, but would be more difficult
if the developers had used codebehind (eg. requires Visual Studio or a
command line compiler).
Regards, Kenneth Skovhede, GEOGRAF A/S
Praveen Rajendra Babu skrev:
> The code-behind behaves fine in VS 2008, can't see the Intellisense in
> ASPX markup only.
> Also, please confirm whether MG API code can reside in code-behind
> too. All examples(atleast the ones I have seen)
> seems to be in the ASPX markup only.
> Regards,
> Praveen
> *From:* Praveen Rajendra Babu
> *Sent:* Monday, 12 January 2009 4:22 PM
> *To:* 'mapguide-users at lists.osgeo.org'
> *Subject:* MapGuide API Intellisense in Visual Studio
> Hello,
>      Is anyone there who has implemented/implementing/plan to for
> intellisense support in Visual Studio?!
> Any suggestions/directions would be highly appreciated.
> Thanks and regards,
> Praveen
> mapguide-users mailing list
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090112/99511888/attachment.html
