[mapguide-users] Theme layer - error
Arnaud De Groof
Arnaud.DeGroof at spacebel.be
Mon Jan 12 09:02:23 EST 2009
I have a problem with the function "Theme layer". With the Sheboygan
example (district layer), the function is successful used but when I try
to use this function with my different polygon layers, the following
error is encountered during the process:
Error: An exception occurred in DB XML component.
Error: XML Indexer: Parse error in document at line, 72, char
12. Parser message: Not enough elements to match content model :
'((LineStyle,Thickness,Color,Unit,SizeContext),ExtendedData1)'
StackTrace:
- MgResourceServiceHandler.ProcessOperation line 80 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services
\resource\ResourceServiceHandler.cpp
- MgOpSetResource.Execute line 103 file
\resource\OpSetResource.cpp
- MgServerResourceService.SetResource line 713 file
\resource\ServerResourceService.cpp
- MgRepositoryManager.SetResource line 867 file
\resource\RepositoryManager.cpp
- MgRepositoryManager.AddResource line 840 file
- MgResourceContentManager.AddResource line 183 file
\resource\ResourceContentManager.cpp
- MgResourceContentManager.PutDocument line 624 file
- MgResourceDefinitionManager.PutDocument line 554 file
\resource\ResourceDefinitionManager.cpp An exception occurred
Error: XML Indexer: Parse error in document at line, 72, char 12.
Moreover, is it possible to configure this function aiming to apply a
graduated color depending to the attribute value?
Thanks.
Regards,
Arnaud De Groof
___________________________________________________________________________________
E-MAIL DISCLAIMER
The present message may contain confidential and/or legally privileged information.
If you are not the intended addressee and in case of a transmission error,
please notify the sender immediately and destroy this E-mail.
Disclosure, reproduction or distribution of this document and its possible
attachments is strictly forbidden.
SPACEBEL denies all liability for incomplete, improper, inaccurate, intercepted,
(partly) destroyed, lost and/or belated transmission of the current information
given that unencrypted electronic transmission cannot currently be guaranteed
to be secure or error free. Upon request or in conformity with formal, contractual
agreements, an originally signed hard copy will be sent to you to confirm
the information contained in this E-mail.
SPACEBEL denies all liability where E-mail is used for private use.
SPACEBEL cannot be held responsible for possible viruses that might corrupt this
message and/or your computer system.
____________________________________________________________________________________
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090112/eee5a073/attachment.html
