[mapguide-users] Theme layer - error
Zac Spitzer
zac.spitzer at gmail.com
Mon Jan 12 09:10:34 EST 2009
can you post your layer xml?
On Tue, Jan 13, 2009 at 1:02 AM, Arnaud De Groof
<Arnaud.DeGroof at spacebel.be> wrote:
> Hi,
> I have a problem with the function "Theme layer". With the Sheboygan example
> (district layer), the function is successful used but when I try to use this
> function with my different polygon layers, the following error is
> encountered during the process:
> Error: An exception occurred in DB XML component.
> Error: XML Indexer: Parse error in document at line, 72, char 12.
> Parser message: Not enough elements to match content model :
> '((LineStyle,Thickness,Color,Unit,SizeContext),ExtendedData1)'
> StackTrace:
> - MgResourceServiceHandler.ProcessOperation line 80 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\ResourceServiceHandler.cpp
> - MgOpSetResource.Execute line 103 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\OpSetResource.cpp
> - MgServerResourceService.SetResource line 713 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\ServerResourceService.cpp
> - MgRepositoryManager.SetResource line 867 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\RepositoryManager.cpp
> - MgRepositoryManager.AddResource line 840 file
> - MgResourceContentManager.AddResource line 183 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\ResourceContentManager.cpp
> - MgResourceContentManager.PutDocument line 624 file
> - MgResourceDefinitionManager.PutDocument line 554 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\ResourceDefinitionManager.cpp
> Error: XML Indexer: Parse error in document at line, 72, char 12. Parser
> Moreover, is it possible to configure this function aiming to apply a
> graduated color depending to the attribute value?
> Thanks.
> Regards,
> Arnaud De Groof
> ________________________________
> E-MAIL DISCLAIMER
> The present message may contain confidential and/or legally privileged
> information. If you are not the intended addressee and in case of a
> transmission error, please notify the sender immediately and destroy this
> E-mail. Disclosure, reproduction or distribution of this document and its
> possible attachments is strictly forbidden.
> SPACEBEL denies all liability for incomplete, improper, inaccurate,
> intercepted, (partly) destroyed, lost and/or belated transmission of the
> current information given that unencrypted electronic transmission cannot
> currently be guaranteed to be secure or error free.
> Upon request or in conformity with formal, contractual agreements, an
> originally signed hard copy will be sent to you to confirm the information
> contained in this E-mail.
> SPACEBEL denies all liability where E-mail is used for private use.
> SPACEBEL cannot be held responsible for possible viruses that might corrupt
> this message and/or your computer system.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
