[mapguide-users] Problems with selection
clarkie342
f2000342 at gmail.com
Mon Jan 12 14:32:38 EST 2009
Is there a solution to the initial issue here? I came across the same thing
but I do not have any joins in the feature source.
Here is the javascript that I have to update the selection.
var selectionXml =
document.getElementById("ctl00_ContentPlaceHolder1_hfSelectXml").getAttribute("value");
var mapFrame =
document.getElementById("viewerFrame").contentWindow.GetMapFrame();
mapFrame.SetSelectionXML(selectionXml);
mapFrame.Refresh();
the status bar shows 1 feature selected but no feature is highlighted. I
also tried manual refresh of the map(from context menu) that did not
highlight the selected features either. Appreciate any help.
Thanks.
Andy Morsell wrote:
> Yes, it does say that a feature is selected. Technically, it still is
> since
> the selection object exists on the server and is not disposed of when you
> turn the layer off. This is most likely by design and I find it would
> probably be more desirable than not to have that selection object reappear
> when the layer is turned back on if it was the last thing I had selected.
> If you want to clear the selection, even when the layer is turned off, you
> can use the Clear Selection through the interface or programmatically.
> Andy
> _____
> From: Butler, Juan P [mailto:jpbutler at co.pinellas.fl.us]
> Sent: Thursday, April 20, 2006 11:05 AM
> To: users at mapguide.osgeo.org
> Subject: RE: [mapguide-users] Problems with selection
> Thanks Andy.
> Check to see on the status bar if it states that an object is selected
> when
> the layer is turned off. My highlight goes away, but the map still has an
> object selected.
> - Juan
> _____
> From: Andy Morsell [mailto:amorsell at spatialgis.com]
> Sent: Thu 4/20/2006 1:16 PM
> I am seeing the same thing in regards to the joined feature (polygons
> joined
> to Access) not highlighting when selected but the attributes do show up in
> the Properties pane. I am also seeing some general weirdness with this
> layer. If I turn it off in the legend, it does not turn off on the map (a
> request to the server does not occur) until I select an object. Panning
> and
> zooming aren't forcing the refresh. I suspect these are related issues
> and
> the refresh flag is getting stuck when interacting with these types of
> layers.
> I don't see the same thing as you in the second case. If I select an
> object
> and it highlights and then turn off that layer, the highlight turns off as
> well. When that layer is turned back on, the highlight also reappears.
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com
> _____
> Sent: Thursday, April 20, 2006 9:36 AM
> Some more observations...
> It seems that when I select my parcel layer that is tied to my Access
> database, the highlight feature doesn't work. When I switch over to use
> just the layer that is based strictly on the sdf file, the highlighting
> works. So I guess it has something to do with layers that are tied to an
> Access database. Can someone else please try this and let me know if they
> are seeing this?
> Also, when I select a feature and then turn of the layer of the selected
> feature, the feature seems to still be selected. Odd.
> FYI: I'm using the AJAXViewer
> - Juan
> _____
> Sent: Thu 4/20/2006 12:05 PM
> Subject: [mapguide-users] Problems with selection
> Has anyone experienced problems with features not highlighting after
> selection? The data appears in the Properties frame, but the feature
> isn't
> highlighted. Plus, the bottom of the map states 1 feature selected. It's
> only on my parcel polygon layer. My other polygon layers select and
> highlight fine. Weird.
> Another thing I noticed was when I had a feature selected from this layer,
> if I go to zoom out or pan, the map locks up and does nothing unless I
> unselect the feature.
> - Juan
View this message in context: http://n2.nabble.com/Problems-with-selection-tp1804059p2147489.html
