[mapguide-users] Problems with selection
Mark Pendergraft markp at Meadgilman.com
Mon Jan 12 17:47:05 EST 2009
What about zooming to the feature using the maps Zoom to selection
method:
ExecuteMapAction(10);
Does the map zoom to the correct feature?  Is it highlighted afterwards?
-Mark P.
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of clarkie342
Sent: Monday, January 12, 2009 11:33 AM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] Problems with selection
Is there a solution to the initial issue here? I came across the same
thing
but I do not have any joins in the feature source.
Here is the javascript that I have to update the selection.
                    var selectionXml =
document.getElementById("ctl00_ContentPlaceHolder1_hfSelectXml").getAttr
ibute("value");
                    var mapFrame =
document.getElementById("viewerFrame").contentWindow.GetMapFrame();
                    mapFrame.SetSelectionXML(selectionXml);
                    mapFrame.Refresh();
the status bar shows 1 feature selected but no feature is highlighted. I
also tried manual refresh of the map(from context menu) that did not
highlight the selected features either. Appreciate any help.
Thanks.
Andy Morsell wrote:
> Yes, it does say that a feature is selected.  Technically, it still is
> since
> the selection object exists on the server and is not disposed of when
you
> turn the layer off.  This is most likely by design and I find it would
> probably be more desirable than not to have that selection object
reappear
> when the layer is turned back on if it was the last thing I had
selected.
> If you want to clear the selection, even when the layer is turned off,
you
> can use the Clear Selection through the interface or programmatically.
> Andy
>   _____
> From: Butler, Juan P [mailto:jpbutler at co.pinellas.fl.us]
> Sent: Thursday, April 20, 2006 11:05 AM
> To: users at mapguide.osgeo.org
> Thanks Andy.
> Check to see on the status bar if it states that an object is selected
> when
> the layer is turned off.  My highlight goes away, but the map still
has an
> object selected.
> - Juan
>   _____
> From: Andy Morsell [mailto:amorsell at spatialgis.com]
> Sent: Thu 4/20/2006 1:16 PM
> I am seeing the same thing in regards to the joined feature (polygons
> joined
> to Access) not highlighting when selected but the attributes do show
up in
> the Properties pane.  I am also seeing some general weirdness with
this
> layer.  If I turn it off in the legend, it does not turn off on the
map (a
> request to the server does not occur) until I select an object.
Panning
> and
> zooming aren't forcing the refresh.  I suspect these are related
issues
> and
> the refresh flag is getting stuck when interacting with these types of
> layers.
> I don't see the same thing as you in the second case.  If I select an
> object
> and it highlights and then turn off that layer, the highlight turns
off as
> well.  When that layer is turned back on, the highlight also
reappears.
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com
>   _____
> Sent: Thursday, April 20, 2006 9:36 AM
> Some more observations...
> It seems that when I select my parcel layer that is tied to my Access
> database, the highlight feature doesn't work.  When I switch over to
use
> just the layer that is based strictly on the sdf file, the
highlighting
> works.  So I guess it has something to do with layers that are tied to
an
> Access database.  Can someone else please try this and let me know if
they
> are seeing this?
> Also, when I select a feature and then turn of the layer of the
selected
> feature, the feature seems to still be selected.  Odd.
> FYI: I'm using the AJAXViewer
> - Juan
>   _____
> Sent: Thu 4/20/2006 12:05 PM
> Subject: [mapguide-users] Problems with selection
> Has anyone experienced problems with features not highlighting after
> selection?  The data appears in the Properties frame, but the feature
> isn't
> highlighted.  Plus, the bottom of the map states 1 feature selected.
It's
> only on my parcel polygon layer.   My other polygon layers select and
> highlight fine.  Weird.
> Another thing I noticed was when I had a feature selected from this
layer,
> if I go to zoom out or pan, the map locks up and does nothing unless I
> unselect the feature.
> - Juan
View this message in context:
http://n2.nabble.com/Problems-with-selection-tp1804059p2147489.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
