[mapguide-users] Problems with selection
clarkie342
f2000342 at gmail.com
Thu Jan 15 13:56:08 EST 2009
I was using RegisterClientScriptBlock in code-behind to set the selectionxml
to the mapframe. This was not working so I changed my logic to do
clientcallback so now I am setting the selectionxml in the aspx page itself.
this seems to work.
Not sure why the difference. sorry did not get a chance to test the below
scenerio.
Thanks for the response.
Mark Pendergraft wrote:
> What about zooming to the feature using the maps Zoom to selection
> method:
> ExecuteMapAction(10);
> Does the map zoom to the correct feature? Is it highlighted afterwards?
> -Mark P.
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of clarkie342
> Sent: Monday, January 12, 2009 11:33 AM
> To: mapguide-users at lists.osgeo.org
> Subject: RE: [mapguide-users] Problems with selection
> Is there a solution to the initial issue here? I came across the same
> thing
> but I do not have any joins in the feature source.
> Here is the javascript that I have to update the selection.
> var selectionXml =
> document.getElementById("ctl00_ContentPlaceHolder1_hfSelectXml").getAttr
> ibute("value");
> var mapFrame =
> document.getElementById("viewerFrame").contentWindow.GetMapFrame();
> mapFrame.SetSelectionXML(selectionXml);
> mapFrame.Refresh();
> the status bar shows 1 feature selected but no feature is highlighted. I
> also tried manual refresh of the map(from context menu) that did not
> highlight the selected features either. Appreciate any help.
> Thanks.
> Andy Morsell wrote:
>> Yes, it does say that a feature is selected. Technically, it still is
>> since
>> the selection object exists on the server and is not disposed of when
> you
>> turn the layer off. This is most likely by design and I find it would
>> probably be more desirable than not to have that selection object
> reappear
>> when the layer is turned back on if it was the last thing I had
> selected.
>> If you want to clear the selection, even when the layer is turned off,
> you
>> can use the Clear Selection through the interface or programmatically.
>> Andy
>> _____
>> From: Butler, Juan P [mailto:jpbutler at co.pinellas.fl.us]
>> Sent: Thursday, April 20, 2006 11:05 AM
>> To: users at mapguide.osgeo.org
>> Thanks Andy.
>> Check to see on the status bar if it states that an object is selected
>> when
>> the layer is turned off. My highlight goes away, but the map still
> has an
>> object selected.
>> - Juan
>> _____
>> From: Andy Morsell [mailto:amorsell at spatialgis.com]
>> Sent: Thu 4/20/2006 1:16 PM
>> I am seeing the same thing in regards to the joined feature (polygons
>> joined
>> to Access) not highlighting when selected but the attributes do show
> up in
>> the Properties pane. I am also seeing some general weirdness with
> this
>> layer. If I turn it off in the legend, it does not turn off on the
> map (a
>> request to the server does not occur) until I select an object.
> Panning
>> and
>> zooming aren't forcing the refresh. I suspect these are related
> issues
>> and
>> the refresh flag is getting stuck when interacting with these types of
>> layers.
>> I don't see the same thing as you in the second case. If I select an
>> object
>> and it highlights and then turn off that layer, the highlight turns
> off as
>> well. When that layer is turned back on, the highlight also
> reappears.
>> Andy Morsell, P.E.
>> Spatial Integrators, Inc.
>> http://www.SpatialGIS.com
>> _____
>> Sent: Thursday, April 20, 2006 9:36 AM
>> Some more observations...
>> It seems that when I select my parcel layer that is tied to my Access
>> database, the highlight feature doesn't work. When I switch over to
> use
>> just the layer that is based strictly on the sdf file, the
> highlighting
>> works. So I guess it has something to do with layers that are tied to
> an
>> Access database. Can someone else please try this and let me know if
> they
>> are seeing this?
>> Also, when I select a feature and then turn of the layer of the
> selected
>> feature, the feature seems to still be selected. Odd.
>> FYI: I'm using the AJAXViewer
>> - Juan
>> _____
>> Sent: Thu 4/20/2006 12:05 PM
>> Subject: [mapguide-users] Problems with selection
>> Has anyone experienced problems with features not highlighting after
>> selection? The data appears in the Properties frame, but the feature
>> isn't
>> highlighted. Plus, the bottom of the map states 1 feature selected.
> It's
>> only on my parcel polygon layer. My other polygon layers select and
>> highlight fine. Weird.
>> Another thing I noticed was when I had a feature selected from this
> layer,
>> if I go to zoom out or pan, the map locks up and does nothing unless I
>> unselect the feature.
>> - Juan
> http://n2.nabble.com/Problems-with-selection-tp1804059p2147489.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://n2.nabble.com/Problems-with-selection-tp1804059p2164233.html
