[mapguide-users] Simple Query. How to.
irwan
anakando at yahoo.com
Mon Jan 12 21:19:24 EST 2009
this is what i'm looking for..but what if i used data from sql query? for
example
$result = 'select * from building where size > 120 ';
from you code sample below , $_GET['afznr'] contain only 1 value. but
$result may contain more than 1 values. So what should i do?can i do like
this-
$node->nodeValue = '"afz_nr" = '$result'';
thanks
Willem Schwarte wrote:
> You can create a layer in studio as how it should look, and save this as
> a XML file (menu File).
> Then you can load this XML as a new layer in your code and set the
> FILTER (id=1 or whatever) add the layer to your map and refresh (or
> not).
> This is how I do this. There is an example on the example site on
> osgeo.org.
> Something like this:
> // Change the filter
> $xpath = new DOMXPath($domDocument);
> $query = '//Filter';
> // Get a list of all the <AreaRule><Filter> elements in
> // the XML.
> $nodes = $xpath->query($query);
> // Find the correct node and change it , this is the filter
> foreach ($nodes as $node )
> $node->nodeValue = '"afz_nr" = '.$_GET['afznr'].'';
> // Add the layer to the map
> $layerDefinition = $domDocument->saveXML();
> $newLayer = add_layer_definition_to_map($layerDefinition,
> "newlayer", "Route", $sessionId, $resourceService, $map,0);
> Willem
> -----Oorspronkelijk bericht-----
> Van: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] Namens MaciekS
> Verzonden: maandag 12 februari 2007 15:33
> Aan: mapguide-users at lists.osgeo.org
> Onderwerp: [mapguide-users] Simple Query. How to.
> Hi MapGuide developers.
> Does somebody know how to filter data on specified, existing layer?
> I added a layer from a SHP file to my repository using MapGuide Studio.
> Now I'd like to filter this layer from my code with a simple query, for
> example (where ID=1).
> How should I built my code to execute the query that finally will
> display in
> the browser only polygons specified in the query?
> Regards, Maciek
> http://www.nabble.com/Simple-Query.-How-to.-tf3214017s16610.html#a892519
> 4
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://n2.nabble.com/Simple-Query.-How-to.-tp1808729p2149157.html
