[mapguide-users] invalid XML document
irwan anakando at yahoo.com
Mon Jan 12 22:16:55 EST 2009
does anybody here know what is my xml problem?
<LayerDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:noNamespaceSchemaLocation="LayerDefinition-1.1.0.xsd" version="1.1.0">
 <VectorLayerDefinition>
<ResourceId>Library://UPM/Data/BUILD_BUILD_region.FeatureSource</ResourceId>
  <FeatureName>Default:BUILD_BUILD_region</FeatureName>
  <FeatureNameType>FeatureClass</FeatureNameType>
  <PropertyMapping>
   <Name>NAME</Name>
   <Value>NAME</Value>
  </PropertyMapping>
  <Geometry>Geometry</Geometry>
<Url>concat(&apos;http://128.88.31.35:8008/mapguide/UPM/phpscripts/bom/activeWR.php?bl_id=&apos;,
&quot;ID&quot;)</Url>
  <VectorScaleRange>
   <MaxScale>6958.1596415586</MaxScale>
   <AreaTypeStyle>
    <AreaRule>
     <Filter>FeatId &gt; 10</Filter>
     <LegendLabel></LegendLabel>
     <Label>
      <Unit>Inches</Unit>
      <SizeContext>DeviceUnits</SizeContext>
      <SizeX>0.3</SizeX>
      <SizeY>0.118110236220472</SizeY>
      <Rotation>0.0</Rotation>
      <Text>&quot;NAME&quot;</Text>
      <FontName>Arial Black</FontName>
      <ForegroundColor>H0H0H0H</ForegroundColor>
      <BackgroundColor>HHHHHHH</BackgroundColor>
      <BackgroundStyle>Ghosted</BackgroundStyle>
      <HorizontalAlignment>&apos;Center&apos;</HorizontalAlignment>
      <VerticalAlignment>Halfline</VerticalAlignment>
      <Bold>true</Bold>
     </Label>
     <AreaSymbolization2D>
      <Fill>
       <FillPattern>Net_45</FillPattern>
      </Fill>
      <Stroke>
       <LineStyle>Solid</LineStyle>
       <Thickness>0.0</Thickness>
       <Color>FF000000</Color>
       <Unit>Centimeters</Unit>
      </Stroke>
     </AreaSymbolization2D>
    </AreaRule>
   </AreaTypeStyle>
  </VectorScaleRange>
  <VectorScaleRange>
   <MinScale>6958.1596415586</MinScale>
   <AreaTypeStyle>
    <AreaRule>
      <Fill>
      </Fill>
      <Stroke>
       <Thickness>0</Thickness>
       <Color>ff666666</Color>
       <Unit>Inches</Unit>
      </Stroke>
    </AreaRule>
   </AreaTypeStyle>
  </VectorScaleRange>
 </VectorLayerDefinition>
</LayerDefinition>
 i create this xml from mapguide studio. i intend to create a new layer
programatically using this xml file that calling from
change_layers_via_dom.php code sample. what i do here is changed
DOMDocument::Load to load my xml file and also change a node value that
satisfy my query.
    $domDocument = DOMDocument::load('RecentlyBuilt.LayerDefinition.xml');
    if ($domDocument == NULL)
        echo "The layer definition
          'RecentlyBuilt.LayerDefinition' could not be
          found.<BR>\n";
        return;
    // Change the filter
    $xpath = new DOMXPath($domDocument);
    $query = '//AreaRule/Filter';
    // Get a list of all the <AreaRule><Filter> elements in the XML.
    $nodes = $xpath->query($query);
    // Find the correct node and change it
    foreach ($nodes as $node )
        if ($node->nodeValue == 'FeatId > 10')
            $node->nodeValue = 'FeatId > 10';
    // Change the legend label
    $query = '//LegendLabel';
    // Get a list of all the <LegendLabel> elements in the
    // XML.
    // Add the layer to the map
    $layerDefinition = $domDocument->saveXML();
    $newLayer = add_layer_definition_to_map($layerDefinition,
"RecentlyBuilt", "FeatId > 10", $sessionId, $resourceService, $map);
    add_layer_to_group($newLayer, "Analysis", "Analysis", $map);
    // Turn off the "Square Footage" themed layer (if it
    // exists) so it does not hide this layer.
    $layerCollection = $map->GetLayers();
    if ($layerCollection->Contains("SquareFootage"))
        $squareFootageLayer =
          $layerCollection->GetItem("SquareFootage");
        $squareFootageLayer->SetVisible(false);
    // Turn on the visibility of this layer.
    // (If the layer does not already exist in the map, it will be visible
by default when it is added.
    // But if the user has already run this script, he or she may have set
the layer to be invisible.)
    if ($layerCollection->Contains("RecentlyBuilt"))
        $recentlyBuiltLayer = $layerCollection->GetItem("RecentlyBuilt");
        $recentlyBuiltLayer->SetVisible(true);
 Once i ran the code, there is nothing happened. then i copy the link to new
browser, but it show this error message
ERROR: The new XML document is invalid.
Can you tell me what is my problem?
View this message in context: http://n2.nabble.com/invalid-XML-document-tp2149327p2149327.html
