[mapguide-users] [ZS2] Re: Filter on joined database values
irwan
anakando at yahoo.com
Wed Jan 14 10:37:16 EST 2009
wow many thanks!! you help me a lot.
Kenneth Skovhede, GEOGRAF A/S wrote:
> This is the filter:
> $QueryFilter='Drawing+%3D+%26apos%3B74%26apos%3B+AND+Dept+%3D+%26apos%3B136%26apos%3B'
> For some reason the PHP xml system does not seem to autoencode the
> stuff, you must xml encode your input.
> I don't know why the above is url encoded though.
> The un-encoded filter should look like:
> $QueryFilter = 'Drawing = "3B74" AND Dept = "3B136"'
> The Xml encoded version should look like this:
> No expert on PHP functions, but I found this to help you out:
> http://vantol.org/node/31
> The $QueryFilter is the string you should change to match your list of
> values.
> Build the list like this:
> $res = '';
> while(odbc_fetch_row($rs))
> $bl_id=odbc_result($rs,"bl_id");
> $res .= $bl_id;
> $res .= ',';
> $res = substr($res, 0, -1); //Remove the last ,
> $QueryFilter = xmlencode('ID IN ('.$res.')');
> (Note: If the values are not integers, they have to be surrounded with
> quotes).
> (Note: You filter column in the SDF may not be called ID).
> (Note: xmlencode is the function from the link given)
> Regards, Kenneth Skovhede, GEOGRAF A/S
>>> IIRC, something is broken, so you can't filter on a joined database.
>>> Instead, you can select keys from the database with an sql like this:
>>> select distinct key from table where somecolumn = 'somecriteria';
>>> The sql should then give you a list of keys.
>>> You can then set the layer filter like this:
>>> "ID" IN (...comma seperated key list...)
>>> ea: "ID" IN ('1','A')
>> i really stucked! really dont have an idea to change Filter element in
>> xml.what i want to know here is how to pass a value that i get from sql
>> query(php) to xml?i have create a php script, a very simple one to query
>> data from database.
>> $wr_selected="SELECT * FROM wr WHERE bl_id = 'Rev";
>> $rs=odbc_exec($conn,$wr_selected);
>> currently $bl_id hold a value that satisfy a query. So i want this value
>> put
>> into the <Filter></Filter> element in xml file such as <Filter>BL_ID IN
>> $bl_id</Filter> but i know this is something we cannot do.
>> I look at this code from
>> // Load the Query Match Layer Definition template into a PHP DOM
>> object
>> and
>> // modify its Filter node so we're displaying the right building and
>> floor.
>> $doc = DOMDocument::load('QueryMatch.LayerDefinition.xml');
>> $FilterNode = $doc->getElementsByTagName('Filter')->item(0);
>> $FilterNode->nodeValue = $QueryFilter;
>> $LayerDefinition = $doc->saveXML();
>> $byteSource = new MgByteSource($LayerDefinition,
>> strlen($LayerDefinition));
>> $byteSource->SetMimeType(MgMimeType::Xml);
>> $tempResourceID = new
>> MgResourceIdentifier("Library://HumboldtFM/Layers/QueryMatch.LayerDefinition");
>> $resourceService->SetResource($tempResourceID,
>> $byteSource->GetReader(),
>> null);
>> but i really dont know that to do with this code. Can someone here assist
>> me?
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/invalid-XML-document-tp2149327p2157416.html
