[mapguide-users] [ZS2] Re: Filter on joined database values
irwan anakando at yahoo.com
Thu Jan 15 01:40:37 EST 2009
Kenneth,
howdy...everything is fine but,  i can't encode 'ID IN ('.$res.')'. What
should i do now
irwan wrote:
> wow many thanks!! you help me a lot.
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> This is the filter:
>> $QueryFilter='Drawing+%3D+%26apos%3B74%26apos%3B+AND+Dept+%3D+%26apos%3B136%26apos%3B'
>> For some reason the PHP xml system does not seem to autoencode the
>> stuff, you must xml encode your input.
>> I don't know why the above is url encoded though.
>> The un-encoded filter should look like:
>> $QueryFilter = 'Drawing = "3B74" AND Dept = "3B136"'
>> The Xml encoded version should look like this:
>> No expert on PHP functions, but I found this to help you out:
>> http://vantol.org/node/31
>> The $QueryFilter is the string you should change to match your list of
>> values.
>> Build the list like this:
>> $res = '';
>> while(odbc_fetch_row($rs))
>> 	$bl_id=odbc_result($rs,"bl_id");
>> 	$res .= $bl_id;
>> 	$res .= ',';
>> $res = substr($res, 0, -1); //Remove the last ,
>> $QueryFilter = xmlencode('ID IN ('.$res.')');
>> (Note: If the values are not integers, they have to be surrounded with
>> quotes).
>> (Note: You filter column in the SDF may not be called ID).
>> (Note: xmlencode is the function from the link given)
>> Regards, Kenneth Skovhede, GEOGRAF A/S
>>>> IIRC, something is broken, so you can't filter on a joined database.
>>>> Instead, you can select keys from the database with an sql like this:
>>>> select distinct key from table where somecolumn = 'somecriteria';
>>>> The sql should then give you a list of keys.
>>>> You can then set the layer filter like this:
>>>> "ID" IN (...comma seperated key list...)
>>>> ea: "ID" IN ('1','A')
>>>  i really stucked! really dont have an idea to change Filter element in
>>> xml.what i want to know here is how to pass a value that i get from sql
>>> query(php) to xml?i have create a php script, a very simple one to query
>>> data from database.
>>> $wr_selected="SELECT * FROM wr WHERE bl_id = 'Rev";
>>> $rs=odbc_exec($conn,$wr_selected);
>>> currently $bl_id hold a value that satisfy a query. So i want this value
>>> put
>>> into the <Filter></Filter> element in xml file such as <Filter>BL_ID IN
>>> $bl_id</Filter> but i know this is something we cannot do.
>>> I look at this code from
>>>    // Load the Query Match Layer Definition template into a PHP DOM
>>> object
>>> and
>>>    // modify its Filter node so we're displaying the right building and
>>> floor.
>>>    $doc = DOMDocument::load('QueryMatch.LayerDefinition.xml');
>>>    $FilterNode = $doc->getElementsByTagName('Filter')->item(0);
>>>    $FilterNode->nodeValue = $QueryFilter;
>>>    $LayerDefinition = $doc->saveXML();
>>>    $byteSource = new MgByteSource($LayerDefinition,
>>> strlen($LayerDefinition));
>>>    $byteSource->SetMimeType(MgMimeType::Xml);
>>>    $tempResourceID = new
>>> MgResourceIdentifier("Library://HumboldtFM/Layers/QueryMatch.LayerDefinition");
>>>    $resourceService->SetResource($tempResourceID,
>>> $byteSource->GetReader(),
>>> null);
>>> but i really dont know that to do with this code. Can someone here
>>> assist
>>> me?
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/invalid-XML-document-tp2149327p2161106.html
