[ZS2] Re: [mapguide-users] [ZS2] Re: Filter on joined database values
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Jan 15 05:30:38 EST 2009
What do you mean?
The result of that operation is a string.
All strings can be encoded into xml.
Regards, Kenneth Skovhede, GEOGRAF A/S
irwan skrev:
> Kenneth,
> howdy...everything is fine but,  i can't encode 'ID IN ('.$res.')'. What
> should i do now
> irwan wrote:
>> wow many thanks!! you help me a lot.
>> Kenneth Skovhede, GEOGRAF A/S wrote:
>>> This is the filter:
>>> $QueryFilter='Drawing+%3D+%26apos%3B74%26apos%3B+AND+Dept+%3D+%26apos%3B136%26apos%3B'
>>> For some reason the PHP xml system does not seem to autoencode the
>>> stuff, you must xml encode your input.
>>> I don't know why the above is url encoded though.
>>> The un-encoded filter should look like:
>>> $QueryFilter = 'Drawing = "3B74" AND Dept = "3B136"'
>>> The Xml encoded version should look like this:
>>> No expert on PHP functions, but I found this to help you out:
>>> http://vantol.org/node/31
>>> The $QueryFilter is the string you should change to match your list of
>>> values.
>>> Build the list like this:
>>> $res = '';
>>> while(odbc_fetch_row($rs))
>>> 	$bl_id=odbc_result($rs,"bl_id");
>>> 	$res .= $bl_id;
>>> 	$res .= ',';
>>> $res = substr($res, 0, -1); //Remove the last ,
>>> $QueryFilter = xmlencode('ID IN ('.$res.')');
>>> (Note: If the values are not integers, they have to be surrounded with
>>> quotes).
>>> (Note: You filter column in the SDF may not be called ID).
>>> (Note: xmlencode is the function from the link given)
>>>>> IIRC, something is broken, so you can't filter on a joined database.
>>>>> Instead, you can select keys from the database with an sql like this:
>>>>> select distinct key from table where somecolumn = 'somecriteria';
>>>>> The sql should then give you a list of keys.
>>>>> You can then set the layer filter like this:
>>>>> "ID" IN (...comma seperated key list...)
>>>>> ea: "ID" IN ('1','A')
>>>>  i really stucked! really dont have an idea to change Filter element in
>>>> xml.what i want to know here is how to pass a value that i get from sql
>>>> query(php) to xml?i have create a php script, a very simple one to query
>>>> data from database.
>>>> $wr_selected="SELECT * FROM wr WHERE bl_id = 'Rev";
>>>> $rs=odbc_exec($conn,$wr_selected);
>>>> currently $bl_id hold a value that satisfy a query. So i want this value
>>>> put
>>>> into the <Filter></Filter> element in xml file such as <Filter>BL_ID IN
>>>> $bl_id</Filter> but i know this is something we cannot do.
>>>> I look at this code from
>>>>    // Load the Query Match Layer Definition template into a PHP DOM
>>>> object
>>>> and
>>>>    // modify its Filter node so we're displaying the right building and
>>>> floor.
>>>>    $doc = DOMDocument::load('QueryMatch.LayerDefinition.xml');
>>>>    $FilterNode = $doc->getElementsByTagName('Filter')->item(0);
>>>>    $FilterNode->nodeValue = $QueryFilter;
>>>>    $LayerDefinition = $doc->saveXML();
>>>>    $byteSource = new MgByteSource($LayerDefinition,
>>>> strlen($LayerDefinition));
>>>>    $byteSource->SetMimeType(MgMimeType::Xml);
>>>>    $tempResourceID = new
>>>> MgResourceIdentifier("Library://HumboldtFM/Layers/QueryMatch.LayerDefinition");
>>>>    $resourceService->SetResource($tempResourceID,
>>>> $byteSource->GetReader(),
>>>> null);
>>>> but i really dont know that to do with this code. Can someone here
>>>> assist
>>>> me?
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090115/7a75b9ab/attachment.html
