[mapguide-users] Installing Mapguide Step by step Process
Jackie Ng
jumpinjackie at gmail.com
Thu Jan 15 03:33:35 EST 2009
The sample folder should be in the "www" folder, so that ..\webconfig.ini
will be pointing to a directory one level below it. (ie. It's looking for
C:\Program
Files\MapGuideOpenSource2.0\WebServerExtensions\www\webconfig.ini)
Hope that helps,
- Jackie
Anushri wrote:
> Hi,
> I am using .net 2.0
> Can you please help me by telling step by step installation process of
> Mapguide.
> There is some problem as i run sample it gives me error..
> Configuration file
> "C:\ProgramFiles\MapGuideOpenSource2.0\WebServerExtensions\www\../webconfig.ini"
> cannot be found or cannot be opened.
> Regards,
> Anushri
View this message in context: http://n2.nabble.com/Installing-Mapguide-Step-by-step-Process-tp2161103p2161392.html
