[mapguide-users] Installing Mapguide Step by step Process
irwan anakando at yahoo.com
Thu Jan 15 03:49:31 EST 2009
Try this.
http://mapguide.osgeo.org/sites/mapguide.osgeo.org/files/InstallMapGuideOpenSourceSamples.pdf
Anushri wrote:
> Hi Jackie,
> I have already kept "dotnetviewersample" folder in "www" folder.
> I am working on .Net 2.0.
> Can u plz send me step by step procedure of installing mapGuide?
> Thanks & Regards,
> Anushri
> Jackie Ng wrote:
>> The sample folder should be in the "www" folder, so that ..\webconfig.ini
>> will be pointing to a directory one level below it. (ie. It's looking for
>> C:\Program
>> Files\MapGuideOpenSource2.0\WebServerExtensions\www\webconfig.ini)
>> Hope that helps,
>> - Jackie
>> Anushri wrote:
>>> Hi,
>>> I am using .net 2.0
>>> Can you please help me by telling step by step installation process of
>>> Mapguide.
>>> There is some problem as i run sample it gives me error..
>>> Configuration file
>>> "C:\ProgramFiles\MapGuideOpenSource2.0\WebServerExtensions\www\../webconfig.ini"
>>> cannot be found or cannot be opened.
>>> Regards,
>>> Anushri
View this message in context: http://n2.nabble.com/Installing-Mapguide-Step-by-step-Process-tp2161103p2161429.html
