[mapguide-users] asp site setup
Ed Jobe
ed57gmc-bus at yahoo.com
Thu Jan 15 13:12:27 EST 2009
Well, I'm new to asp, so maybe I'm not doing something right. What I'm trying to set up is a site at C:\inetpub\wwwroot where the main asp site lives but with mapguide as part of the solution so that users who login to the main site will already be logged in to mapguide. I also want to have a parallel site for development. But I don't want to copy all the mapguide stuff, just the www folder. However, my first attempt at this returned a lot of compile errors for broken links.
I started server development by getting mapguide up and running. Now I need to focus on getting the main site up and integrated with mapguide. My VS project only showed regular folders under wwwroot. It didn't show the virtual folder for mapguide. So I tried opening mapguide as a site, but VS only sees that as a regular site. IOW, if I want to add a new page to the mapguide application, only html page templates are shown. None of the asp templates show up. I can't find a way in IIS or VS to turn an existing application into an asp application. BTW, I'm using IIS7 on Server2008 and VS 2008.
So I'm still struggling with the concepts of good site organization. The asp guides I've seen so far only show you how to create a new site under wwwroot. I can't find anything that speaks about best practices for site organization and development and then publishing. Once I get over that, coding should be a breeze.
Ed Jobe
From: "Kenneth Skovhede, GEOGRAF A/S (via Nabble)" <ml-user+64672-1813992732 at n2.nabble.com>
To: Ed Jobe <ed57gmc-bus at yahoo.com>
Sent: Thursday, January 15, 2009 2:35:23 AM
Subject: Re: [mapguide-users] asp site setup
Short answer: yes, it is possible.
But you will have to manually set up the PHP and mapagent.fcgi mappings
in IIS
on the new location.
The steps here should explain what you need to setup in the new location:
http://trac.osgeo.org/mapguide/wiki/MGOS2onVistaIIS7
I can't think of a situation where you would think this was a better
solution though.
Could you elaborate on the kind of trouble you have?
Regards, Kenneth Skovhede, GEOGRAF A/S
Ed Jobe skrev:
> I'm having difficulty setting up the organization of my asp website. I keep
> running into issues due to having the Mapguide www folder in Program Files.
> Is is possible to move this folder to my inetpub folder?
> Ed Jobe
mapguide-users mailing list
mapguide-users at ...
http://lists.osgeo.org/mailman/listinfo/mapguide-users
This email is a reply to your post @ http://n2.nabble.com/asp-site-setup-tp2152742p2161751.html
You can reply by email or by visting the link above.
View this message in context: http://n2.nabble.com/asp-site-setup-tp2152742p2163990.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090115/3e4cfc16/attachment.html
