[mapguide-users] erro compile mapguide
Jack Lee
jack.lee at autodesk.com
Mon Jan 19 07:41:26 EST 2009
You should use FDO 3.3.
________________________________________
From: mapguide-users-bounces at lists.osgeo.org [mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer [zac.spitzer at gmail.com]
Sent: Monday, January 19, 2009 1:58 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] erro compile mapguide
2.0.2 doesn't use 3.40, it's 3.2 (??) i believe
you need to be using the right corresponding verions
z
On Mon, Jan 19, 2009 at 5:19 PM, crossroad <jesuchristopher at gmail.com> wrote:
> I have compiled Fdo-3.4.0 should work well.
> how can I make the compiled using this library?
> the library is downloaded from the svn
> zspitzer wrote:
>> have compiled or installed the FDO binaries?
>> On Mon, Jan 19, 2009 at 4:32 PM, crossroad <jesuchristopher at gmail.com>
>> wrote:
>>> Hi all,
>>> i have the following error:
>>> /usr/bin/ld: cannot find -lFDO-3.3.0
>>> collect2: ld returned 1 exit status
>>> make[3]: *** [mgserver] Error 1
>>> make[3]: Leaving directory `/usr/local/mapguide-2.0.2/Server/src/Core'
>>> make[2]: *** [all-recursive] Error 1
>>> make[2]: Leaving directory `/usr/local/mapguide-2.0.2/Server/src'
>>> make[1]: *** [all-recursive] Error 1
>>> make[1]: Leaving directory `/usr/local/mapguide-2.0.2/Server'
>>> thank
>>> Christopher
>>> View this message in context:
>>> http://n2.nabble.com/erro-compile-mapguide-tp2179937p2179937.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> Zac Spitzer -
>> http://zacster.blogspot.com
>> +61 405 847 168
> View this message in context: http://n2.nabble.com/erro-compile-mapguide-tp2179937p2180040.html
Zac Spitzer -
+61 405 847 168
