[mapguide-users] Mapguide raster problem
Stefan Dalakov
s.dalakov at mapware.net
Mon Jan 19 08:39:15 EST 2009
I use latest MGOS with Apache on Win Server 2003 (as I have 1.2 running
on the same server on IIS), and I use 150 Mb tiff. No problems so far on
both. Have you tested with tiff files ?
Regards : Stefan Dalakov
marius.360 wrote:
> Hi all,
> I posted a message a while ago regarding MGOS being very unstable and
> crashing a lot. Since then I have removed the raster layer from the map and
> it has improved a lot, not crashing once since then (about 4 days). The
> layer was displaying quite large MrSid files, +- 150mb each, with about 50
> files. This is quite a big problem, as the rasters are cricital in the map.
> Does anyone know of a workaround for this raster problem, or if it will work
> if I convert my raster to some other format? I read about tiling but that
> doesn't sound any better. I am using the latest version of MGOS on Windows
> Server 2003 with .net and IIS6 setup. Any help will be appreciated!
> Kind Regards,
> Marius
