[mapguide-users] Mapguide raster problem
marius.360 marius at osssa.co.za
Mon Jan 19 08:45:47 EST 2009
I have not tested with tiff's yet, I am a bit worried about the size a
converted mrsid might be, as well as loss of quality when I convert to tiff.
But it might be worth a try as that will still be better than an unstable
system.
Stefan Dalakov wrote:
> I use latest MGOS with Apache on Win Server 2003 (as I have 1.2 running
> on the same server on IIS), and I use 150 Mb tiff. No problems so far on
> both. Have you tested with tiff files ?
> Regards : Stefan Dalakov
> marius.360 wrote:
>> Hi all,
>> I posted a message a while ago regarding MGOS being very unstable and
>> crashing a lot. Since then I have removed the raster layer from the map
>> and
>> it has improved a lot, not crashing once since then (about 4 days). The
>> layer was displaying quite large MrSid files, +- 150mb each, with about
>> 50
>> files. This is quite a big problem, as the rasters are cricital in the
>> map.
>> Does anyone know of a workaround for this raster problem, or if it will
>> work
>> if I convert my raster to some other format? I read about tiling but that
>> doesn't sound any better. I am using the latest version of MGOS on
>> Windows
>> Server 2003 with .net and IIS6 setup. Any help will be appreciated!
>> Kind Regards,
>> Marius
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Mapguide-raster-problem-tp2180266p2181312.html
