[mapguide-users] Creating Packages dynamically
padmini godavarthi
godavarthi.padmini at gmail.com
Tue Jan 20 01:31:16 EST 2009
Hi Kenneth,
Thanks for u r reply.
u said that "Creating packages is an administrative task, so I won't expect
many API
users to have a need for it".but i want to load layers from oracle
dynamically
(i mean to say if i have a,b,c tables in oracle.i ant to load a,b or b,c or
a,c layers based on requirement programmetically.so i thought dynamic
maestro will support this requirement.)
can u plz tell me
1) How can i achieve this requirement dynamically.
Thanks and Regards,
Padmini.
Rodolfo Moreno wrote:
> thanks Kenneth, It's cool.
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> Yes, you need at least 1.0.9, but the released version has a bug,
>> with creating packages, so you should get the preview release from the
>> download page:
>> http://trac.osgeo.org/mapguide/wiki/maestro/Downloads
>> The package options are found in the "Package" menu.
>> Regards, Kenneth Skovhede, GEOGRAF A/S
>> Rodolfo Moreno skrev:
>>> Hi, I didn't know that Mapguide Maestro can create mapguide packages.
>>> I have 1.0.8.27399 version and I have not found this option.
>>> could you tell me how can I achieve this?
>>> or maybe I need the last maestro version.
>>> Thanks,
>>>> Hello Padmini.
>>>> There are no ready-to-use code in MaestroAPI for authoring (creating)
>>>> MapGuide Packages.
>>>> Creating packages is an administrative task, so I won't expect many API
>>>> users to have a need for it.
>>>> The Maestro application has code that creates and edits packages.
>>>> The code can be found here:
>>>> http://trac.osgeo.org/mapguide/browser/trunk/Tools/Maestro/Maestro/PackageManager
>>>> Especially the file "PackageBuilder.cs" should be of interrest.
>>>> padmini godavarthi skrev:
>>>>> Hi,
>>>>> iam using mapguide opensource 2.0 (with .net 2.0+IIS 5.1)
>>>>> Presently iam using mapguide maestro for creating mapguide
>>>>> packages.but
>>>>> i
>>>>> want to create my package dynamically through coding(using
>>>>> maestroAPI.dll)
>>>>> can any boby plz help me so that it will be very helpful to me.
>>>>> Regards,
>>>>> Padmini.
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> Rodolfo Moreno
>>> CivilEng
View this message in context: http://n2.nabble.com/Creating-Packages-dynamically-tp2167497p2185227.html
