[mapguide-users] Creating Packages dynamically
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Jan 20 03:04:06 EST 2009
Restoring a package is quite a big and cumbersome task.
If you want to load a layer with oracle data, it is much easier to do so,
simply by loading the Xml manually. This can also be done without
Administrator credentials.
I can offer you no more advice than to look at the avalible code.
AFAIK, there is no example code avalible that does exactly what you
want, but the code I pointed you to should make it easier to do so.
Regards, Kenneth Skovhede, GEOGRAF A/S
padmini godavarthi skrev:
> Hi Kenneth,
> Thanks for u r reply.
> u said that "Creating packages is an administrative task, so I won't expect
> many API
>  users to have a need for it".but i want to load layers from oracle
> dynamically
> (i mean to say if i have a,b,c tables in oracle.i ant to load a,b or b,c or
> a,c layers based on requirement programmetically.so i thought dynamic
> maestro will support this requirement.)
> can u plz tell me
> 1) How can i achieve this requirement dynamically.
> Thanks and Regards,
> Padmini.
> Rodolfo Moreno wrote:
>> thanks Kenneth, It's cool.
>> Kenneth Skovhede, GEOGRAF A/S wrote:
>>> Yes, you need at least 1.0.9, but the released version has a bug,
>>> with creating packages, so you should get the preview release from the
>>> download page:
>>> http://trac.osgeo.org/mapguide/wiki/maestro/Downloads
>>> The package options are found in the "Package" menu.
>>> Rodolfo Moreno skrev:
>>>> Hi, I didn't know that Mapguide Maestro can create mapguide packages.
>>>> I have 1.0.8.27399 version and I have not found this option.
>>>> could you tell me how can I achieve this?
>>>> or maybe I need the last maestro version.
>>>> Thanks,
>>>>> Hello Padmini.
>>>>> There are no ready-to-use code in MaestroAPI for authoring (creating)
>>>>> MapGuide Packages.
>>>>> Creating packages is an administrative task, so I won't expect many API
>>>>> users to have a need for it.
>>>>> The Maestro application has code that creates and edits packages.
>>>>> The code can be found here:
>>>>> http://trac.osgeo.org/mapguide/browser/trunk/Tools/Maestro/Maestro/PackageManager
>>>>> Especially the file "PackageBuilder.cs" should be of interrest.
>>>>>> Hi,
>>>>>> iam using mapguide opensource 2.0 (with .net 2.0+IIS 5.1)
>>>>>> Presently iam using mapguide maestro for creating  mapguide
>>>>>> packages.but
>>>>>> i
>>>>>> want to create my package dynamically through coding(using
>>>>>> maestroAPI.dll)
>>>>>> can any boby plz help me so that it will be very helpful to me.
>>>>>> Regards,
>>>>>> Padmini.
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> mapguide-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>> Rodolfo Moreno
>>>> CivilEng
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090120/94ab4583/attachment.html
