[mapguide-users] Creating Packages dynamically
padmini godavarthi
godavarthi.padmini at gmail.com
Tue Jan 20 22:29:08 EST 2009
Hi Kenneth,
Thanks for u r reply.
u told for seeing available code.
but where is that code i didn't get it.
1)how to load xml manually
can u give me an idea so that it will be helpful to me.
Thanks and Regards,
Padmini
Kenneth Skovhede, GEOGRAF A/S wrote:
> Restoring a package is quite a big and cumbersome task.
> If you want to load a layer with oracle data, it is much easier to do so,
> simply by loading the Xml manually. This can also be done without
> Administrator credentials.
> I can offer you no more advice than to look at the avalible code.
> AFAIK, there is no example code avalible that does exactly what you
> want, but the code I pointed you to should make it easier to do so.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> padmini godavarthi skrev:
>> Hi Kenneth,
>> u said that "Creating packages is an administrative task, so I won't
>> expect
>> many API
>> users to have a need for it".but i want to load layers from oracle
>> dynamically
>> (i mean to say if i have a,b,c tables in oracle.i ant to load a,b or b,c
>> or
>> a,c layers based on requirement programmetically.so i thought dynamic
>> maestro will support this requirement.)
>> can u plz tell me
>> 1) How can i achieve this requirement dynamically.
>> Thanks and Regards,
>> Padmini.
>> Rodolfo Moreno wrote:
>>> thanks Kenneth, It's cool.
>>>> Yes, you need at least 1.0.9, but the released version has a bug,
>>>> with creating packages, so you should get the preview release from the
>>>> download page:
>>>> http://trac.osgeo.org/mapguide/wiki/maestro/Downloads
>>>> The package options are found in the "Package" menu.
>>>> Rodolfo Moreno skrev:
>>>>> Hi, I didn't know that Mapguide Maestro can create mapguide packages.
>>>>> I have 1.0.8.27399 version and I have not found this option.
>>>>> could you tell me how can I achieve this?
>>>>> or maybe I need the last maestro version.
>>>>> Thanks,
>>>>>> Hello Padmini.
>>>>>> There are no ready-to-use code in MaestroAPI for authoring (creating)
>>>>>> MapGuide Packages.
>>>>>> Creating packages is an administrative task, so I won't expect many
>>>>>> API
>>>>>> users to have a need for it.
>>>>>> The Maestro application has code that creates and edits packages.
>>>>>> The code can be found here:
>>>>>> http://trac.osgeo.org/mapguide/browser/trunk/Tools/Maestro/Maestro/PackageManager
>>>>>> Especially the file "PackageBuilder.cs" should be of interrest.
>>>>>>> Hi,
>>>>>>> iam using mapguide opensource 2.0 (with .net 2.0+IIS 5.1)
>>>>>>> Presently iam using mapguide maestro for creating mapguide
>>>>>>> packages.but
>>>>>>> i
>>>>>>> want to create my package dynamically through coding(using
>>>>>>> maestroAPI.dll)
>>>>>>> can any boby plz help me so that it will be very helpful to me.
>>>>>>> Regards,
>>>>>>> Padmini.
>>>>>> _______________________________________________
>>>>>> mapguide-users mailing list
>>>>>> mapguide-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>>> Rodolfo Moreno
>>>>> CivilEng
View this message in context: http://n2.nabble.com/Creating-Packages-dynamically-tp2167497p2190356.html
